Vent For Wash Machine - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2009, 09:33 AM   #1
Newly Retired
tuchodi's Avatar
Vent for Wash Machine
I am moving the location of our washing machine to another room. I am going to connect the drain into the same system but it will be farther away from the original drain. Do I need to run a new vent stack up throught the roof or will the old vent allow the water to drain properly.
tuchodi is offline   Reply With Quote
Old 12-20-2009, 10:17 AM   #2
Sorry, but "another room" does not give enough information. There are also local codes that may be affected. The distance from the drainline is what determines what needs to be done. A vent is still required on all fixtures. Not having a vent will cause the trap water to be sucked out and allow sewer gas into the house. You should not need to run the vent through the roof unless the washer is going to be quite a distance from other fixtures already in the area.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-20-2009, 10:37 AM   #3
Newly Retired
tuchodi's Avatar
Thanks for the reply. The distance moved will be 12 feet and it will run into the same line as the original. I will check the local code to make sure.
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Vent for a washing machine drain SmilingBob Plumbing 3 08-23-2009 08:51 PM
washing machine drain vent problems rebelbull Plumbing 7 03-29-2009 09:18 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
