Vent Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2010, 07:26 AM   #1
Rewards Points: 506
Vent valve?
Our kitchen sink has a stub of pipe which tee's up after the trap about 3 inches higher. There is some sort of device screwed into the stub. I don't see a vent pipe anywhere. I think the device has failed...under sink smells putrid!
Is this device some sort of vent check valve? Lets air in but keeps gases in as well?
jlmran is offline   Reply With Quote
Old 04-08-2010, 08:19 AM   #2
fabrk8r
fabrk8r's Avatar
I believe what you are looking at is an "Air Admittance Valve", commonly referred to as a Studor Valve or AAV for short.
http://www.ipscorp.com/studor/minivent
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
jlmran (04-08-2010)
Old 04-08-2010, 09:47 AM   #3
I agree that it is probably an AAV. These are "mechanical" in nature, since they do allow air in, but not out. They can fail, but replacing is easy and quick. The Studor brand is about $23 at Lowes. They do sell a metal one also, for a cheaper price, but over time, I think the Studor will be a better value.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
The Following User Says Thank You to majakdragon For This Useful Post:
jlmran (04-08-2010)
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Vacuum relief valve? walker44 Plumbing 10 08-30-2009 04:33 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
