#16 | |
vent under eave vs puncturing roofQuote:
#17 |
Doing it myself
I think this thread should just be locked at this point. We are beating a dead horse here.
![]() Vents terminate a minimum of 1 foot above eaves, not inside of them, under them, or whatever other tricky ideas you have. They run flat, or they slope toward the fixture served by said vent. Not up, then down, or down, then up, full of water, pine needles, or whatever else you might have blowing in there. Drill a hole through the roof, install a flashing, put a pipe through it, and be done. I don't understand what is so difficult about this process.
Journeyman Plumber |
| The Following 3 Users Say Thank You to Alan For This Useful Post: |
#18 |
agree allan ...this guy does not want the proper way to VENT a fixture....so he can do it the way he wants...iam sure he will anyway.....what a waste of time...everyone have a good evening...ben sr
| The Following User Says Thank You to ben's plumbing For This Useful Post: | rjniles (12-11-2012) |
#19 |
You seem bound and determined to do this your way in spite of all the sound professional advice you've been given. So I'm not going to bother suggesting what I think you should do. But I will tell you what I would do: I prefer to minimize roof penetrations (my current house, which I built and plumbed myself, has only one, the main stack). All the vents tie into it in the attic. I would run your vent pipe up into the attic and terminate it with an AAV if there's not another vent nearby to tie into. Some pros dislike AAVs but they are legal (here at least) and have been around for years. I do have one fixture (kitchen sink) that is vented with an AAV and have not had any problems.
#20 |
if sound and professional advice came with cash to cover my losses I would gladly take it problem is that after all is said and done I am left to cover the cost of doing it wrong and then redoing it
I have to redo the vent system because I hired an expert plumber who messed up the job. I have to redo the roof because I hired an expert roofer who messed up the job. If I do things myself I may mess them up. But if I do I can only blame and be angry at myself. As it is I'm angry at experts and truth be told I have lost confidence in them. I have found that it's better to do some research, listen to people's opinions, then decide for yourself rather than to blindly follow people who claim to be experts. Now if all of your brilliant advice comes down to is "because it's code" then thank you. That in and of itself is of no value to me. That said I have benefited from all your good advice. It is even good to know what the code specifies. I will end my toilet vent above the roof not under the eave. You have convinced me that this is the smart thing to do. The vent will not penetrate the metal roof however. Instead I will use 2" furring strips instead of the 3/4" I usually use when doing metal roofs. 2" (1.5" actual size) of furring strips will create an air gap between the current roof (asphalt shingles) and the metal roof which will lead upward toward the ridge cap at a 1:3 slope. The ridge cap will have 2" holes bored in the front and rear of the gable covered only by a screen to keep the birds out. Also known as gable end vents. The gable end vent is approx. 10-11 feet above grade about the same height as the current vent ends. Please do not get spasticated and confuse this with an attic. I'm going to install a metal roof 2" above the current asphalt shingle roof. We're talking about using the air gap between the current roof and the new roof as a vent. See pix below... http://tj.jjt.partyconnect.me/construction/cottage/ Notice the rocks on the roof? It gets windy on the ranch and asphalt shingles just do not pass the test. 24 guage metal with Kynar 500 infra-red reflecting paint should have been used in the first place. Last edited by jackdiy; 12-12-2012 at 03:25 PM. |
#21 |
Perhaps you didn't read what I wrote or you didn't see the picture of the rocks on the roof. Let me repeat it. Asphalt shingles do not pass the test on the ranch. It is often windy and they flap and break away. In windy areas there are two roof options that I know of. Ceramic tiles and metal. I don't like ceramic tiles because they act as a heat reservoir. They stay hot for a long time after the sun goes down and at night when you want it to cool down. A 24 guage metal roof with Kynar 500 (infrared-reflective) paint is the best solution in my opinion.
Here is a similar discussion to ours regarding vents and metal roofs... Vent Pipes Through Metal Roof which leads to this Correct Way to Flash a Vent Pipe With Metal Roof? which leads to the bottom line: The bottom line is that there is no good way to run a vent through a metal roof. So having a metal roof is not standard on residential development. So every so often you get a by-the-book and do-it like everyone else contractor who does not like this solution and calls it zany. So what? |
#22 | |
| The Following User Says Thank You to ben's plumbing For This Useful Post: | plummen (12-13-2012) |
#23 |
It's a no-win situation. Break through the roof is bad. Don't is bad. There is a perfectly good third option but you guys don't like it because it's not kosher. End of discussion. Why stick around to aggravate each other?
Regarding your concern about doing things legit. I will gladly explain things in private email. It's a touchy subject which I prefer not to discuss on an internet forum. Write to me and I'll reply: bogusemail28@yahoo.com |
#24 |
Roofmaster
if wind is the issue, why didnt you just put on a fully adhered 60 mill epdm roof, turn it down at the perimeter, and nail on a .050" aluminum drip edge and strip it in with 9 inch pressure sensitive flashing? Then you could easily pipe the vent through the roof, and install a pressure sensitive witches hat flashing on your pipe. To keep it cool, coat it with white acrylic.
Last Attempt, you dont listen |
#25 |
Moderator
Getting off topic and plain rude, thread closed. OP, start another thread for new questions, if needed, thank you. Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| Display Modes | |
| very difficult house to vent roof help please | marlowe | Roofing/Siding | 7 | 09-10-2011 12:57 PM |
| Ridge vent on 2:12 slope cathedral roof | DaveM75 | Roofing/Siding | 4 | 08-19-2010 12:06 PM |
| Best roof cap for range hood vent | bsperr | HVAC | 0 | 08-05-2010 03:33 PM |
| Removing Plumbing Vent from Roof | WaldenL | Roofing/Siding | 5 | 08-24-2009 03:30 PM |
| Vent dryer through flat membrane roof | Vince Rosati | General Discussion | 6 | 11-02-2008 03:11 PM |
