Vent stack ruining dormer plans!
What is your roof pitch?
They make the ABS angles in 22, 45 and 67 deg sizes....
Cut the cast iron off using a sawzall (I lot easier than it sounds...yes, easier)
Use a rubber coupling to couple a street elbo of the right angle in....angle does not have to be perfect...the ABS has enough give as well as the rubber coupling.
And as the guys above said....run it up the roof to a new location....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
