Vent Stack For 3x Sinks - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2012, 06:36 PM   #1
Vent stack for 3x sinks
Hi all,
From what I learned in the other thread about our toilet, I am going to assume that the following is NOT ok, due to one of the sinks being over 6' from where the vent stack is currently located?
Is my only option to give that solitary sink by the toilet it's own vent stack?
weekendwarrior9 is offline   Reply With Quote
Old 10-09-2012, 08:54 PM   #2
that would work fine. the 2 sinks together could use the same drain. where is the vent for the toilet? if close enough the single sink vent can vent the toilet also.
Old 10-09-2012, 09:00 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
depending on your governing code, you can go 8 feet on a 2 inch waste arm and depending on how the complete bathroom is vented you could vent all three sinks on a single stack, again your code permitting.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 10-09-2012, 09:23 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They don't have to be within 6 feet of a vent stack, they have to have their own vent within "X distance" My version of UPC on a 2" line is 5 feet, and 1-1/2" line is 3.5 feet.
Hold on, more drawings coming up.......
Journeyman Plumber
Old 10-09-2012, 09:29 PM   #5
Doing it myself
Alan's Avatar
On the left is an example of the trap arm being run horizontally in the wall for a lav or a kitchen. That has to meet the minimum distance from trap weir to vent. IE 5 feet for 2" or 3.5 feet for 1.5"
On the right is an example of a vent below the floor for a shower (similar to one of the toilet drawings I put in the other thread) Same rules apply there.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
weekendwarrior9 (10-10-2012)
Old 10-09-2012, 10:01 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 556
Originally Posted by weekendwarrior9 View Post
Hi all,
Ya know Mr. Warrior,
You have asked how to vent a toilet, shower and lavs. You've received answers from several plumbers from across the country- all using different codes.
Where are you located? Do you know your governing code? Is this a single story or are you using lower level vent stacks to drain into?
Give us a drawing showing your existing plumbing and I'm sure one of us will draw something for you
Allen likes to draw
Old 10-09-2012, 10:05 PM   #7
Doing it myself
Alan's Avatar
Originally Posted by TheEplumber View Post
Allen likes to draw
Mostly dirty pictures. The iso's come as a byproduct of that.
Journeyman Plumber
Old 10-10-2012, 12:12 AM   #8
Sorry, I didn't want to confuse a single thread with multiple different questions.
I live in California. We are on California Plumbing Code 2010 (UPC 2009).
It is a single story dwelling, perimeter foundation.
No existing plumbing, everything was ripped out by previous owners, or by us as we came through and replaced the badly damaged walls. Only thing left are various holes in the subfloor, and the location of where I need the main sewer tie-in to be.
I really appreciate the help, trying to learn as I go here. Trying to understand the principals behind the answers ya'll are giving so I can apply to similar scenarios.
Old 10-10-2012, 12:15 AM   #9
I see. And I presume that the 5' is the total run of the pipe, so 2 feet through one wall, then 90deg turn, then 3 feet in the next wall to meet up by the 5 foot limit?
Old 10-10-2012, 08:09 PM   #10
Doing it myself
Alan's Avatar
True, but then you're talking 2 x 90 degree turns, and that isn't really allowed. It's referred to as "dirty arming" and one 90 degree turn is all that's allowed on a trap arm less than 3"
Journeyman Plumber
Old 10-10-2012, 08:11 PM   #11
Doing it myself
Alan's Avatar
In otherwords, your original drawing looks just fine to me, i was simply trying to explain the distance rule.
Journeyman Plumber
question about vent stack firstimereno Plumbing 7 05-22-2012 10:47 PM
Venting sink within 16" of vent stack jefsboys Plumbing 11 03-19-2012 12:13 PM
Vent stack for kitchen sink stan 41943 Plumbing 19 03-16-2008 05:50 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 03:23 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 02:47 PM
