Vent On Sink Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2009, 02:11 AM   #1
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
Vent on sink drain?
I will be installing my kitchen sink drain pipe soon. Some people have told me I don't need an outside vent because it is not on a toilet drain. It is stand alone. Half way down the chiminey drain ties in so that is a vent in a way. So, does a sink need a roof vent? Thanks, Dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 06-27-2009, 06:16 AM   #2
Vent pipes or waste stacks are needed for 2 reasons. the first is to pipe sewer gases up and out of the system to prevent the associated problems with trapped methane, not normally a problem with just a sink but very necessary with toilets. Secondly a vent allows for the equalization of pressure in the drain lines so that water flows out and down through to your sewer system. Without proper ventilation air bubbles can get trapped and water will not flow easily from a sink. The most common symptom is a sink that gurgles when draining or will not drain rapidly. With this thought in mind all plumbing fixtures should be connected to a vent stack and you should have adequate venting for the entire house. The addition of a new fixture to a vent system can cause problems to existing plumbing if the vent system is overloaded.
faucetman886 is offline   Reply With Quote
Old 06-27-2009, 06:57 AM   #3
Whatamess
You can install an AAV (Air Admittance Valve) in most areas. Check the code.
http://www.ipscorp.com/studor/maxivent
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 06-27-2009, 11:32 AM   #4
Dorf dude...
After posting I did some research. I should have done that first. Yep, need a vent for sure. Thanks, Dorf dude...
Sink won't drain kchopper Plumbing 5 06-07-2009 10:42 PM
Sink Drain Pump Vent Handyman101 Plumbing 0 03-11-2009 12:43 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 06:28 PM
