Vent Routing / Alternatives? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2012, 10:58 AM   #1
Rewards Points: 150
Just a quick question for you guys. Are there alternatives to venting to the roof, or to the main stack above highest rim level. I have a bathroom on the main floor that was never vented (must have been common back then). Venting correctly would mean alot of work routing the vent to the stack, not to mention my home has no attic access (1.5 storey 1940 construction). I don't want to use an AAV. Can I tie into the stack midway or does it have to be above all other rim levels? Can I vent through the side of the home?
Finally, what is the proper way to vent a toilet? An explanation or schematic would be helpful.
I'm in Canada if that helps, but I encourage advice from all.
psilva8 is offline   Reply With Quote
Old 01-13-2012, 11:04 AM   #2
Rewards Points: 3,130
It all depends on the applicable code where you live. The two most common, IRC and UPC, approach venting in very different ways. For example, under IRC (where I live) toilets don't have to be vented at all, while under UPC they do. One code prohibits AAVs (I think), while the other allows them.
Why are you opposed to using an AAV? I think they get a bad rap. I've had at least one in several of my houses and never had a problem with any of them.
Old 01-13-2012, 11:12 AM   #3
Rewards Points: 150
I've heard they need to be accessible and I don't want to put a mystery door in a wall.
If I do use one, do I just need to worry about sizing it accordingly and make sure it gets installed above highest rim level? If so, does it need to be above highest rim for the entire home, or just the bathroom is serves?
I've heard about them failing and the fact they don't provide for positive venting (like the initial flush of the toilet that pushes the air ahead, although I assume this is less of an issue).
Thanks for the response.
Old 01-13-2012, 07:22 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 348
Is this toilet having issues so you think you need to vent it?
You can tie into a properly sized vent stack above 42"
Depends on your local code
Try google- toilet venting
Hope this helps
Old 01-13-2012, 07:28 PM   #5
Rewards Points: 150
Yes. It will flush, but I will hear the shower trap slosh with water and the toilet tries to suck air behind it and burps. I should note this bathroom has been re-plumbed at some point with ABS piping and no vents added in.
I'm sorry but could you clarify this a bit. 42" above what, and is this the case even if there is another bathroom that ties into the stack on the upper level of the home?
I'll try that.
Hope this helps
It has.
Old 01-13-2012, 11:13 PM   #6
Plumber
Rewards Points: 348
horizontal vents should tie into vent stacks 6" above the flood rim of the highest fixture. As a rule of thumb, 36" is the highest fixture(kitchen sink). Add 6" and now you're at the magic height of 42"
New Roof marknok Roofing/Siding 4 08-06-2011 12:41 PM
Will this bath vent routing work? Homerepairguy Kitchen & Bath Remodeling 5 01-05-2011 07:05 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
