Vent Requirement For Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2011, 06:58 PM   #1
Vent requirement for shower
I would like to install a shower in my basement, and it would be located five feet from main 4" wet stack that vents through the roof.
There's a toilet placed a couple of feet away from the main stack and I hope to wye into the pipe that carries the toilet waste. (when I break up the concrete floor)
This an older building with cast iron soil pipes.
So, my question is, can I install the shower without a vent, as its only a five foot run to the stack.
Old 12-17-2011, 07:04 PM   #2
Rewards Points: 582
1st.... not sure if code even allows wet venting.....2nd you run the risk of having your trap seal pulled every time toilets are flushed without a vent....I would try to get a vent off that shower if at all possible..
Old 12-17-2011, 10:31 PM   #3
Thanks for your reply, Ben! If I were to vent the shower, I would have to use a mechanical vent. To vent it through the roof would require me to run through a bedroom on the main floor.
I wondered about running a vent line on the outside of the house, but winter temps here are below freezing for four months and I wonder if warm, moisture laden air would freeze inside the pipe and cause a blockage.
Old 12-17-2011, 10:38 PM   #4
Rewards Points: 582
I really think what you are going to do will work,,,but I have to keep in mind what i would do for my customer and the plumbing code in pa... so don't sweat it if you can't do it try it like you plan...maybe leave a vent in wall caped off..if it pulls trap seal then try auto vent,,????
Old 12-17-2011, 11:13 PM   #5
Thats an excellent suggestion and thats exactly what I will do.
There's a floor drain in the same vacinity and I've never had a problem with its trap being pulled.
Thank you!
Old 12-18-2011, 07:46 PM   #6
Rewards Points: 582
Thank you!
good deal glad to help
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 07:11 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 04:31 PM
