Vent Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2012, 11:25 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 348
Originally Posted by REXAMUS View Post
Is it acceptable to tie the tub drain into the toilet using a wye? Are there any other ways that may be better to do this?
Code in my area will not allow this. no branch lines on a toilet arm
Old 03-14-2012, 11:47 PM   #17
Rewards Points: 89
http://ecodes.biz/ecodes_support/fre..._plumbing.html
Looked through all of that and didn't locate anything. If anyone is bored feel free to pinpoint where it talks about it and I'll check it out.
REXAMUS is offline   Reply With Quote
Old 03-15-2012, 02:23 PM   #18
Rewards Points: 89
post deleted
Old 03-15-2012, 11:12 PM   #19
Master Plumber
Javiles's Avatar
Rewards Points: 984
If you donít have any prior plumbing drainage experience reading the codes is just reading the codes, the interpretation is where you get your answers.
Here is your answer
Each plumbing fixture trap, except as otherwise provided in this code, shall be protected against siphonage and back-pressure, and air circulation shall be ensured throughout all parts of the drainage system by means of vent pipes installed in accordance with the requirements by this code
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Will this bath vent routing work? Homerepairguy Kitchen & Bath Remodeling 5 01-05-2011 07:05 PM
Questions about installing bathroom vent fan tripower Building & Construction 8 12-31-2009 09:15 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 04:17 PM
"B" Vent Question SteveSmith98 HVAC 4 01-02-2009 09:12 AM
