Vent Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2012, 07:58 PM   #1
Rewards Points: 89
Vent questions
I've been trying to learn the do's and dont's of plumbing..while tearing my bathroom apart I discovered that the toilet was not vented at all. I wanted to make sure I did everything correct and made a few diagrams.
My drawing ability is not very good so let me know if you have any questions.
Would both setups work for vent purposes?
REXAMUS is offline   Reply With Quote
Old 03-08-2012, 08:58 AM   #2
Rewards Points: 3,130
A toilet does not require a separate vent. It's connection to the main stack is the vent.
Old 03-08-2012, 09:03 AM   #3
Rewards Points: 150
Typically if its within 5' of the vent stack you are good to go. Check your local plumbing code just to be safe.
psilva8 is offline   Reply With Quote
Old 03-08-2012, 09:33 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Here, each fixture has it's own, including toilets.
Please check your local code to be sure that what you are doing is OK.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
jaydevries (03-08-2012), TheEplumber (03-08-2012)
Old 03-08-2012, 03:59 PM   #5
Rewards Points: 636
hard to tell from drawing what is what but all vents have to be higher then fixtures buy at least 6 inches
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-08-2012, 11:11 PM   #6
Rewards Points: 89
Here's a more realistic view of the second one....I'll check my local codes too.
Old 03-08-2012, 11:20 PM   #7
Rewards Points: 636
to me it is vented you can run so far before the vent is needed and you are under that distance
Old 03-08-2012, 11:37 PM   #8
Rewards Points: 89
Yea, I found this so I should be good. Anything is better then NO vent like it was previously.
Old 03-08-2012, 11:49 PM   #9
Rewards Points: 636
some codes say you do not need to vent the toilet
Old 03-09-2012, 07:45 AM   #10
Quite so. The applicable code where I built my house three years ago was IRC 2003. Venting is handled much differently than in the more common UPC. My toilets are not separately vented, all my vents combine so I have only one roof penetration (the main stack), and there' an AAV venting the kitchen sink. Everything works just fine.
Old 03-14-2012, 09:06 PM   #11
Rewards Points: 89
Is it acceptable to tie the tub drain into the toilet using a wye? Are there any other ways that may be better to do this?
Old 03-14-2012, 09:32 PM   #12
GC/Master Plumber/Mech
Rewards Points: 560
THat diagram is International code
Uniform code is quite different
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-14-2012, 10:04 PM   #13
Rewards Points: 89
That chart came from the online publication for my local code.
Old 03-14-2012, 10:16 PM   #14
Master Plumber
Javiles's Avatar
Rewards Points: 996
That chart does not apply to the toilet. .. Showers tubs sinks etc trapped waste arms. Not the W/C
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-14-2012, 10:22 PM   #15
Master Plumber
Javiles's Avatar
Rewards Points: 996
You cannot connect a fixture on the toilet waste arm as in this drawing.
Will this bath vent routing work? Homerepairguy Kitchen & Bath Remodeling 5 01-05-2011 06:05 PM
Questions about installing bathroom vent fan tripower Building & Construction 8 12-31-2009 08:15 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 03:17 PM
"B" Vent Question SteveSmith98 HVAC 4 01-02-2009 08:12 AM
