Vent Problem With Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2008, 09:18 PM   #1
vent problem with sink
the homes here are 60-80 year old row homes. every sink in these homes is tied in to one vent exiting the roof. most pipes are buried in plaster walls. how can I add more vents so some of the sinks don't back up so much.
cal111 is offline   Reply With Quote
Old 01-21-2008, 09:51 PM   #2
Union HVAC Tech.
Add a studor vent (air admittance valve) to the piping below the sink.
bigMikeB is offline   Reply With Quote
Old 01-22-2008, 03:37 PM   #3
I blame ProWallGuy
Rewards Points: 150
How did you come to the determination that the vents were the problem?
Double A is offline   Reply With Quote
Old 01-23-2008, 11:36 AM   #4
I don't think the problem is with the vent. At that age, the drains are probably cast iron with galvanized steel "arms" from each fixture to the main drain and venting. There is most likely sediment/rust and perhaps even holes in the galvanized pipe which causes blockages.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-23-2008, 09:44 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Yes 1st thing is to get the lines cleaned out.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
bathroom vent fan - condensation problem jaspar General DIY Discussions 16 03-23-2012 11:54 AM
sink vent? redline Plumbing 6 03-13-2008 04:32 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 06:28 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
Pedistal sink..is this a problem? Dusty Plumbing 6 09-22-2006 03:48 PM
