-   -   Vent problem or other?? (http://www.diychatroom.com/f7/vent-problem-other-24026/)
javan 07-21-2008 01:08 PM
Last year I installed new fixtures in my bathroom. The new toilet (low-flush from Kholer) work great for most of the time. however, let's just say that I tend to "clog" toilets routinely. With this new one, I can not just grab the plunger and plunge-away. I find that when I plunge, I can hear the sound of air going up the vent. I am not sure what the issue is, but the solution is for me to go on the roof, cover the vent with my hand, while somebody inside plunges.
Ideas?
Marlin 08-02-2008 04:27 PM
In the past you were getting clogs before the vent. You are now getting clogs after the vent. I'd look into a better flushing toilet. Or you could get a toilet auger however if you have a lead bend using it on a regular basis will eventually damage it.
javan 08-03-2008 08:18 AM
I never used the original toilet, so I have no idea if the problem was there before....
majakdragon 08-03-2008 10:12 AM
If someone needs to block the vent to plunge, this tells me the main drainline is the problem and the vent is clear. If you cannot find a clean-out, you may need to remove the toilet and auger out the line from there.
Marlin 08-03-2008 10:29 AM
The answer then that you are not clogging the toilet, you are clogging the waste line further down the line past your vent. You can probably use a toilet auger to clear it without having to have someone go up on the roof. For a long term solution look into a better flushing toilet, even a pressure tank if necessary.
