Vent Piping In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2009, 09:00 AM   #1
vent piping in attic
first time at this site, seems like a great info tool, my question is horizontal vent piping in the attic i know it needs to be run at a pitch to drain but is there a certain height above the truss boards, do you bury it in the blown in insulation or keep above that level?thank you for any input very appreciated
demano is offline   Reply With Quote
Old 05-23-2009, 10:18 AM   #2
A slight pitch will aid in drainage of condensation, and insulating is beneficial in a cold climate
Chemist1961 is offline   Reply With Quote
Old 05-24-2009, 12:06 AM   #3
Registered User
Termite's Avatar
Insulation's a good thing. The pipe can be covered and just needs enough pitch to flow rainwater.
Old 05-24-2009, 07:50 AM   #4
Vent piping in the attic will have condensation in the winter. If your area has extremely cold temps, insulating the lines would be in your best interest. You may want to call your local Code office and ask if insulation is recommended or required in your area.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-24-2009, 09:49 AM   #5
thank you
thank you all for the info insulation it is
Plugging Range Vent in Attic SPS-1 HVAC 1 12-08-2008 10:40 AM
Soffit Vent Sizing - Really Hot Attic dmo069 Roofing/Siding 7 12-04-2008 09:33 PM
HOT attic, ridge vent/soffit vent questions gone_fishing Roofing/Siding 36 07-14-2008 09:26 PM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
