Old 10-12-2012, 10:29 PM   #1
JOATMON
ddawg16's Avatar
Vent Pipe In Wall?
This is a pic of the sink area....L shaped....there will be 2 sinks (same area that I asked a different question about 2 weeks ago)....the short pieces of pipe sticking up are about where the drains will go....
Left side.....no problem..it does straight down through the wall....other side....because there is a beam under there (a really big beam), I'll run the drain along the floor so that it's hidden by the kick plate area of the vanity....
Now....the vent....left side...not issue....non-load bearing wall...I can drill a hole up to 60% of the stud....but load bearing wall? 1 1/2" pipe? That is 50% of the stud.....
So....do I just run the vent pipe on the outside of the wall? So that it's hidden by the vanity?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 10-13-2012, 12:31 AM   #2
Vent Pipe In Wall?
My basic answer is whatever you can get to work. If you can use a vanity to hide a vent pipe then do it. I find many times venting is overrated. You could bump those drain pipes up to a two inch, then they will act as a vent, possibly. Hard to enlarge those type of holes. You could use those air admitance valves, they leak and go bad, but maybe not these days. See how quality goes up every year.. Ask a plumber, then a carpenter your questions. I am neither, but have done both for many years, possibly the wrong way.
paintdrying is offline   Reply With Quote
Old 10-13-2012, 11:07 AM   #3
Doing it myself
Alan's Avatar
Vent Pipe In Wall?
This is why a lot of places require 2x6 walls wherever plumbing is involved.
You may have to just go straight up with the one in the load bearing wall if you don't want to route it through the cabinet.
Keep in mind that inside of the cabinet you will be below the flood rim of the vanity, so your piping will need to be on grade toward drain and use drainage fittings.
Journeyman Plumber
Old 10-13-2012, 04:48 PM   #4
JOATMON
ddawg16's Avatar
Vent Pipe In Wall?
Oh....I should point out that this is the second floor.....
This is the view from below......the drain will need to come out of that floor about half way down this wall....
My
and
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Vent pipe - horizontal? secutanudu Plumbing 3 03-02-2011 07:23 PM
Insight on framing inset and rerouting vent pipe drcheap Remodeling 7 01-13-2011 04:15 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
