Old 03-06-2010, 01:20 PM   #1
Vent pipe size for toilet
Hi, I'm installing an all new DWV system in a remodel. An inspector said that a 3" drain on a toilet requires a dedicated 3" vent. If I have a dedicated vent, doesn't the size seem excessive? I had in my memory that the vent for a dedicated water closet drain needs only be 1 1/2"
jackyyboy is offline   Reply With Quote
Old 03-06-2010, 10:55 PM   #2
GC/Master Plumber/Mech
Inspector is a little off. If you are venting just a water closet a 1 1/2" should be fine. But I normally run 2" just because it will be easier to snake from the roof and less 1 1/2 to carry.
Have the inspector show you in code where a 1 1/2 vent can't be used for only 1.5 dfu's
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-07-2010, 10:58 AM   #3
retired elect/hvac/plumb
plummen's Avatar
what he said! id use a 2" also for maintenance reasons but 1 1/2" would be legal in my book,just make sure it increases to 4" a foot before daylighting through the roof
plummen is offline   Reply With Quote
Old 03-07-2010, 12:46 PM   #4
Doing it myself
Alan's Avatar
2" is code minimum in Oregon.
Journeyman Plumber
Old 03-09-2010, 02:21 PM   #5
How far is the toilet from the main stack? You might not need a separate vent at all.
Tags
drain, dwv, toilet, vent
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 07:17 PM
iron vent pipe broken at fitting CCarlson Plumbing 3 02-18-2009 08:40 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 06:07 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
framing conundrum: 2" PVC vent pipe going horizontal through 2x4 studs amakarevic Building & Construction 18 01-19-2008 07:47 PM
