Old 10-09-2012, 11:47 AM   #1
Vent Pipe Question
Is this adequate/correct for a vent pipe installation?
Uploaded with ImageShack.us
Litzner is offline   Reply With Quote
Old 10-09-2012, 12:27 PM   #2
Vent Pipe Question
you need a vent on the shower drain also. it can be tied back into the vent from the lav at 42 inches above the floor or higher. if you tie into the lav vent make sure the tee is upside down from the one the lav drains into.
Old 10-09-2012, 12:31 PM   #3
Vent Pipe Question
So the T under the toilet is not sufficient enough to vent the shower?
Old 10-09-2012, 12:41 PM   #4
Vent Pipe Question
in all the states i have worked that would not pass inspection. now if you tee off of the line going to the shower for the lav that would work. im not saying what you have wouldn't work, it just wouldn't pass inspection where i have been.
Utility sink drain pipe question jabergess Plumbing 3 05-06-2011 09:01 AM
Vent Pipe camel604 Plumbing 2 03-06-2011 09:19 PM
Vent pipe - horizontal? secutanudu Plumbing 3 03-02-2011 07:23 PM
Splicing ABS Black Vent Pipe Garfield Plumbing 1 12-07-2009 03:53 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
