Vent Pipe Open In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2012, 01:25 AM   #1
Rewards Points: 1,062
Question
vent pipe open in attic
is it OK to leave a vent pipe open in an unused attic (just really a gap between the ceiling and roof, too small to be used) if there is a sizeable side wall grid vent, maybe 4x10" within a foot of it or so? i just don't feel like drilling through the roof and sealing it and all. currently, that's the way i have it (but have not done the ceilings yet) and A) it vents fine and B) does not stink.
thanks
Old 02-07-2012, 05:09 AM   #2
Rewards Points: 1,512
Some of the gases that rise from a plumbing drain vent are flammable. When allowed to escape into free air, the gases remain at a low enough concentration to not ignite easily.
The Following User Says Thank You to AllanJ For This Useful Post:
amakarevic (02-07-2012)
Old 02-07-2012, 06:30 AM   #3
The correct answer is NO!!! It must go outside, wether thru the roof or sidewall. Flat roofs can be difficult to seal, so go thru the side. Gable roof flashing is easy to install and works well.
The Following User Says Thank You to Just Bill For This Useful Post:
Old 02-07-2012, 08:05 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
Open vent in an attic, this can make everyone in your house sick, we deal with this all the time.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 02-07-2012, 09:11 PM   #5
Rewards Points: 582
needs vented to outside......
Tags
vent pipes
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
Bath room vent pipe banovak1 Plumbing 0 04-05-2011 10:24 AM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
Vent Pipe camel604 Plumbing 2 03-06-2011 08:19 PM
Vent Pipe Stink in house zacker Plumbing 30 12-13-2010 12:19 PM
