Old 04-24-2010, 10:17 AM   #1
Vent Pipe Cap?
I was up on the roff this AM and just now noticed that the waste line vent pipe does not have a cap. Should it?
The pipe is black, 3" diameter, with a rubber boot under the shingles.
Earnie is offline   Reply With Quote
Old 04-24-2010, 11:41 AM   #2
Doing it myself
Alan's Avatar
Vent Pipe Cap?
Wouldn't a cap prevent the flow of air through the system. That's the point of a vent.
Journeyman Plumber
Old 04-24-2010, 01:00 PM   #3
Civil Engineer
Vent Pipe Cap?
There are special vent caps that do not fit tight to the cap. I estimate that less than half of the houses in my area have caps on the vents. I suspect they are not needed because if it rains down the cap, so what, it goes into the drain. The cap is probably there to keep birds, bees etc from nesting in your cap.
Old 04-24-2010, 01:25 PM   #4
Vent Pipe Cap?
Does not need a cap.
SuperPlumberGuy is offline   Reply With Quote
Old 04-24-2010, 02:52 PM   #5
Vent Pipe Cap?
Ok. Thanks.
The bees, bird, or other is what had me wondering.
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Vent pipe size for toilet jackyyboy Plumbing 4 03-09-2010 02:21 PM
Water dripping from vent pipe Rosy_55 Plumbing 4 01-07-2010 10:35 AM
Hot Water Heater Improper Vent Pipe Danger fritzycat1 Plumbing 2 07-27-2009 11:34 AM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 10:43 PM
