Old 04-17-2006, 10:25 AM   #1
To vent or not to vent?
Adding a second floor to my house. There will be a half-bath on that level. The toilet and sink will be about 18 feet from the existing 3 inch pipe that goes vertically from the basement and up through the roof (main floor toilet and fixtures all connect to this pipe). Question is...can I simply run the toilet and sink drains horizontally and tie in where that 3" pipe passes through the new 2nd floor? If not, what venting arrangement should I have for this new bathroom? Does this arrangement require a separate pipe through the roof, or is there a way (is it ok) to connect to the existing vent in the attic? Thanks a ton!!
sootybuttercup is offline   Reply With Quote
Old 04-17-2006, 10:41 PM   #2
A Builder & Plumber
I am a licensed master plumber.
I believe I answered your question in another forum you posted in. I can not copy the link or copy and paste the post, so I'l try to re write it
You can not run 18 feet with the pipe horizontal because you will kill the vent, every trap and trapped fixture needs a vent which can be achieved in any number of ways,
1) Air admittance valve
2) Wet venting
3) Direct vent
First lets say we will use a 3" line horizontally (Sufficiant for toilet and sink, 4" is overkill) Now try to run the line from the toilet to where the sink line will drop down under the floor. Here we should use a 3" x 2" tee wey so we can connect the sink drain in with the toilet. Make sure the 2" side is at the top or at minimal 45 degrees off center (It can not be laid flat as this will kill the vent). Now we can tie in a line for the sink. Run your pipe up through the wall and use a 2"x1-1/2" x 1-1/2" sanitary tee (The 2" opening is at the bottom, the 1-1/2" will point upward to the attic, the other 1-1/2" will catch the sinks drain) Next run 1-1/2" pipe up into the attic, turn a 90 (Elbow) toward the existing vent that goe's through the roof and tie it in (At this point you will want this sanitary tee to be installed upside down for venting) Back under the floor finish running the horizontal and tie into the existing drain. This should work fine, if not you can email me and tell me why it will not work and I can guid you from there. Good luck! And bear in mind that any line used as a vent can not be run horizontally untill it is 6" or higher than the flood rim of the highest fixture it serves
Oldman is offline   Reply With Quote
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Roughed in basement vent question jeffgator Plumbing 5 01-27-2007 12:48 PM
Ridge Vent - Low-pitched roof? brianp Roofing 2 05-08-2006 09:32 PM
Island Hood Vent Centering Problems Dana Remodeling 2 07-13-2005 08:37 AM
