Vent Line Has Goes UP, Down, UP - Can I Drain Lowest Point? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2012, 10:09 PM   #1
Vent line has goes UP, down, UP - can I drain lowest point?
Re-Doing the laundry room and moving the washer from one side of the room to the other. Basically, the vent line for a 2" drain line needs to go under the ibeam for house, before it goes straight to the roof. I'm essentially creating a P trap in the vent line. If I drain that P trap at the lowest point straight into the main stack for the house, can I still use that line as a vent?
I could run the vent so it doesn't have to dip down, but I'd have to drill through 10 joists, which I'd rather not do.
http://imgur.com/a/6UdHR
Thanks!
Last edited by calphalon; 09-18-2012 at 10:21 PM. Reason: Edit: Sorry for typo in title
calphalon is offline   Reply With Quote
Old 09-18-2012, 11:08 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
A vent always goes up- never down
Old 09-19-2012, 07:35 AM   #3
Rewards Points: 582
well if you want it to work....have to do it the proper way..can't go down looks like you need a sharp new bit for your drill.....
Old 09-19-2012, 08:49 AM   #4
Suggestions on an AAV?
Also, if I have the washer/sink on the same line, is it bad to have the P trap below the floor?
Old 09-19-2012, 08:07 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
How about a picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 09-19-2012, 08:35 PM   #6
Drawings work?
Old 09-19-2012, 08:42 PM   #7
plummen's Avatar
oopsies,duplicate!
Old 09-19-2012, 08:51 PM   #8
plummen's Avatar
Are you tying the p-trap into a san tee or is that some sort of s-trap?
Looks like an s-trap dropping into 90 from your picture anyway.
It looks like you should have enough room to cut a wye in there and still loop it back between the floor joists and then bring it up through the floor to cut it into that vent stack higher than the level of the washing machine.
Its not a legal vent unless its tied in above flood level of fixture its venting,if that makes sense to you.
Old 09-19-2012, 09:42 PM   #9
Well, long time ago I did a bathroom, I was trying to cut corners and I didn't have much space for the ptrap to be inside the vanity, so I install one ptrap for the sink and the bathtub. It worked just fine, but after some time I notice some ugly smell coming from the sink, it wasn't easy to get rid of it (only by flushing with lots of water the sink). It was that with normal use, you get soap and shaving foam and hair and all kind of stuff that get stuck to the interior walls of the drain, and they smell because there is no ptrap on the top, only on the bottom and far away.
Long story short, since them I always install every single fixture with it's own ptrap (specially the sink!).
By the way, you can't install 2 p-traps in series, that's a no-no, so plan well in advance.
Pirulo is offline   Reply With Quote
Old 09-19-2012, 09:47 PM   #10
By your drawing, I'd connect the vent just where you draw the blue arrow, and eliminate everything that is to the left of the ibeam, so the vent is actually like a continuation of the 3" stack.
Old 09-19-2012, 10:18 PM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Short answer : No you can't do that.
Journeyman Plumber
Old 09-19-2012, 10:37 PM   #12
Plumber
Rewards Points: 682
Thanks!
my code states p traps for washers must be min. 6" above the floor. So venting on the lower level is pointless.
Old 09-19-2012, 10:38 PM   #13
Doing it myself
Alan's Avatar
Good point. I'm going to go punch myself in the face now for messing that one up.
Journeyman Plumber
Old 09-20-2012, 12:10 AM   #14
ups, vent needs to be between 5' from the ptrap, and the ptrap over the level of the floor, and stack pipe over ptrap be from 18" to 42" max length, should verify distances from local code.
Old 09-20-2012, 01:22 AM   #15
Hey guys,
Thanks for all the help. Looks like the first idea won't work. Here are my other two options... let me know what you think
#1: an AAV in the cabinet for the sink/washer. No other venting.
http://i.imgur.com/izJPd.png
#2. Because the vent line will no longer be connected to anything (since we're moving washer to other side of room), I can attach it to the top of the stack to provide extra venting on the stack. I can also run 3" piping for the horizontal portion of the drain run to the sink/washer to allow some additional venting.
http://i.imgur.com/7kkb7.png
Is this a good AAV? Some people mentioned it takes a bit of vacuum in the water for the valve to first open... is there a better one out there?
http://www.amazon.com/Oatey-39016-Su.../dp/B000BVMX62
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 11:11 AM
Water heater drain pan line Bigmike33 Plumbing 1 09-22-2010 08:29 PM
drain to drain to vent? ryanh Plumbing 0 07-12-2010 12:07 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 07:09 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
