Vent Line Change Of Direction Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2013, 08:36 AM   #1
Send a message via AIM to Rich Send a message via Yahoo to Rich
vent line change of direction fittings
Can a sanitary tee be used to change directions, horizontal to horizontal, on the vent lines? I know there is a table that says you can't do it for drains but wasn't sure if it applied to the vent as well.
Rich is offline   Reply With Quote
Old 03-30-2013, 08:41 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 924
Yes it can- you need to make sure the drainage pattern of the fitting is properly orientated.
The Following User Says Thank You to TheEplumber For This Useful Post:
Rich (04-04-2013)
Vent line has goes UP, down, UP - can I drain lowest point? calphalon Plumbing 22 09-20-2012 09:06 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
