Vent Length Of Run? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2010, 10:06 AM   #1
Vent Length of Run?
Hello all,
I am in the planning stages of moving a basement bathroom (all the way across the basement). Was just wondering how far venting can run horizontally. Not looking forward to breaking into upstairs walls.
Learjetpilot is offline   Reply With Quote
Old 08-13-2010, 01:31 PM   #2
It depends on your state, but you would be safe running a 2" vent up to 150 feet horizontally. Just make sure you put a slight pitch to the pipe incase any water that gets in can drain out. You have to be careful about offsets as well, you can't run a vent horizontally that drops under an obstruction such as a beam or duct, then rise again, that creates a trapped section where water can collect.
The Engineer is offline   Reply With Quote
Old 08-13-2010, 08:31 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
You're right about different states. I can only run a 2" horizontal vent 40'
Old 08-14-2010, 09:15 AM   #4
Thanks very much, I'll check the local codes. It would be a fairly simple but long run.
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Max length for a drain pipe w/o vent Bcoleman6 Plumbing 8 05-06-2008 10:11 AM
