-   -   Vent Length of Run? (http://www.diychatroom.com/f7/vent-length-run-78670/)
Learjetpilot 08-13-2010 10:06 AM
Vent Length of Run?
Hello all,
I am in the planning stages of moving a basement bathroom (all the way across the basement). Was just wondering how far venting can run horizontally. Not looking forward to breaking into upstairs walls.
The Engineer 08-13-2010 01:31 PM
It depends on your state, but you would be safe running a 2" vent up to 150 feet horizontally. Just make sure you put a slight pitch to the pipe incase any water that gets in can drain out. You have to be careful about offsets as well, you can't run a vent horizontally that drops under an obstruction such as a beam or duct, then rise again, that creates a trapped section where water can collect.
TheEplumber 08-13-2010 08:31 PM
199 Attachment(s)
You're right about different states. I can only run a 2" horizontal vent 40' :wink:
Learjetpilot 08-14-2010 09:15 AM
Thanks very much, I'll check the local codes. It would be a fairly simple but long run.
