Vent Inlet Pointing Direction ... - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2007, 08:06 PM   #1
Rewards Points: 1,062
Question
vent inlet pointing direction ...
UP towards the fixture or DOWN towards the outflow ??
if sewer was coming in, then definitely it would be clear that it should be turning downside. but the inlet supplies vent to a fixture (bath tub) up the pipe (and that is all that it is doing) and was thinking that it also would make sense to point it towards it. both options make sense to me. the latter seems like it would provide a more immediate access to venting but does look wierd as well.
please consider the illustration. it can be seen that i have it initially set to point UPSIDE towards where the bath tub outflow will be. but i can switch it easily.
thanks,
- a -
Old 12-29-2007, 08:11 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
BACKWARDS!!
If I am reading this right, the left side of the pic is inlet and the waste will flow to the right? If this is correct, turn the twey over.
USP45 is offline   Reply With Quote
Old 12-29-2007, 08:20 PM   #3
yes, you are right
left is inlet for the tub, right is outflow, the T side is the vent coming from the above. the vent, in this case, is vent ONLY, no flow coming through it.
Old 12-29-2007, 08:23 PM   #4
USP45's Avatar
Rewards Points: 150
Turn it around, it is backwards then. If water travels down the line part of the water will want to go into the vent side of the twey, thus a good place for debris to collect. Then if it has to be cleaned out with a snake, it may want to go up the vent instead of down the drain
Old 12-29-2007, 08:47 PM   #5
Journeyman Plumber
Ron The Plumber's Avatar
Yes it is backwards.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-29-2007, 09:17 PM   #6
Talking
i will turn it around
thanks gurus ! like i was saying in the original post, it will be easy to turn it 180.
- a -
Old 12-29-2007, 09:23 PM   #7
USP45's Avatar
Rewards Points: 150
Glad we could help you out!
Old 12-30-2007, 11:28 AM   #8
it is just unbelievable where technology has gotten us, i mean in the aspect of getting answers so fast. i can't even imagine what i'd have to do 15 yrs ago to get these answers ...
Old 12-30-2007, 12:11 PM   #9
USP45's Avatar
Rewards Points: 150
no telling!
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 09:05 AM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 12:36 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
Better way to protect portable generator inlet? IvoryRing Electrical 7 05-30-2006 07:30 PM
