-   -   vent inlet pointing direction ... (http://www.diychatroom.com/f7/vent-inlet-pointing-direction-14889/)
amakarevic 12-29-2007 09:06 PM
1 Attachment(s)
UP towards the fixture or DOWN towards the outflow ??
if sewer was coming in, then definitely it would be clear that it should be turning downside. but the inlet supplies vent to a fixture (bath tub) up the pipe (and that is all that it is doing) and was thinking that it also would make sense to point it towards it. both options make sense to me. the latter seems like it would provide a more immediate access to venting but does look wierd as well.
please consider the illustration. it can be seen that i have it initially set to point UPSIDE towards where the bath tub outflow will be. but i can switch it easily.
thanks,
- a -
USP45 12-29-2007 09:11 PM
BACKWARDS!!
If I am reading this right, the left side of the pic is inlet and the waste will flow to the right? If this is correct, turn the twey over.
amakarevic 12-29-2007 09:20 PM
yes, you are right
left is inlet for the tub, right is outflow, the T side is the vent coming from the above. the vent, in this case, is vent ONLY, no flow coming through it.
USP45 12-29-2007 09:23 PM
Turn it around, it is backwards then. If water travels down the line part of the water will want to go into the vent side of the twey, thus a good place for debris to collect. Then if it has to be cleaned out with a snake, it may want to go up the vent instead of down the drain
Ron The Plumber 12-29-2007 09:47 PM
Yes it is backwards.
amakarevic 12-29-2007 10:17 PM
i will turn it around
thanks gurus ! like i was saying in the original post, it will be easy to turn it 180.
- a -
USP45 12-29-2007 10:23 PM
Glad we could help you out!
amakarevic 12-30-2007 12:28 PM
it is just unbelievable where technology has gotten us, i mean in the aspect of getting answers so fast. i can't even imagine what i'd have to do 15 yrs ago to get these answers ...
USP45 12-30-2007 01:11 PM
no telling!
