Old 10-10-2009, 12:22 PM   #1
vent fot washer drain
hey all
I have a question concerning the need or not to have a vent for a washer drain
currently my washer is in the basement. running behind is the main lline coming from the toilet upstairs,
They simply tied into it with a 1 1/2" pipe and a p-trap
so...the hose form the washer simply goes into this piece of pipe and is carried off to the main stack which is about 10 feet away.
I've never ha issued with the drain.
I'm in the process of placing the washer in the main level bathroom. I was going to copy the same logic . basically have a pipe and p-trap come up from the basement and then simply tying into the min line from the toilet.
is this ok, or do I need venting of some sort?
trying to find layouts online but coming up short
thanks for any tips...hope I explained my situation clearly
Pabs
Pabs is offline   Reply With Quote
Old 10-11-2009, 12:52 AM   #2
you need to make sure the washer drain is vented in some way. what drain pipe do you intend to tie the new washer drain into?
plumber Jim is offline   Reply With Quote
Old 10-11-2009, 01:14 PM   #3
The previous plumber might have considered it a direct vent.
These diagrams might help:
http://www.inspect-ny.com/plumbing/P...efinitions.htm
walkman is offline   Reply With Quote
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
Vent requirement for laundry washer drain pipe WaldenL Plumbing 9 01-12-2009 08:11 PM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
