Vent Distances - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2012, 08:06 PM   #1
Vent distances
Nightmare in my house! Crappy shower lead to a rip out, wife wanted a tub so I looked under the subfloor for support and.....
Framing wise- whoever plumbed this cut 3x7 inches out of the 10" joists (2) with 15 foot span! Yikes (this is fixable now that all drywall below is off). But I discovered the rest of the plumbing issues. House is 18 years old- 2 story.
One rise, serving one and a half bathrooms, comes from basement up to 2nd floor joists- 90's and travels 12 feet to a 3"Y off to a vertical 3 to roof, and straight to a bath, shower and toilet. Shower and toilet are within vent distance but the tub is 12 feet+. In this case,I am curious as to the vertical to horizontal run. I am accustom to a vertical stack with runs off of it, not a rise-then 12 feet horizontal then rise to roof. What would be the rule here? (revent or something else or is it all legal??).
Another run that serves a toilet and sink, again comes from the basement 90's at the 2nd floor travels 10 feet to the 3-3-2 (sink) and continues to the toilet. No vent at all. I assume a vent is necessary????!!!! If so, could I run a T up 7 feet across the wall and into the other vent. Too close to eve to just run straight up). Is there a formula to vent size in regards to appliances. I this case all in, there is 2 toilets, 2 sinks, 2 tubs (after switching shower to tub). Clear as mud??
Any info will be appreciated. Also, I really want to rip the county apart for passing the original inspections of this!
fireside is offline   Reply With Quote
Old 02-26-2012, 08:15 PM   #2
Rewards Points: 636
picture would be nice
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 02-26-2012, 08:44 PM   #3
And I forgot, the entire 3" line is level- not even close to 1/4 per foot.
Old 02-26-2012, 08:52 PM   #4
Nice joist cutting- keeping in mind this is a 15 foot span. The other joist that was cut is worse!
Old 02-26-2012, 08:54 PM   #5
Rewards Points: 582
wow what a hack man......can some one enlighten me on the yellow glue....30yrs never seen this....
Old 02-26-2012, 09:21 PM   #6
Yellow glue- I was thinking home depot- but that would be orange
I do have to rip out most of the plumbing to get the new joists in. For reinstall I am concerned about the distance from where this pipe Y's and goes up to the roof and where it turns down to basement (12 feet). This kinda seems like a wet vent but there would be a max distance would there not? I could install a T closer, which would go into a wall then tie back into the vent above all connections (revent I guess).
Also, curious about trying to tie the other run into this vent stack as well. I am curious as to the formula used to determine vent size for appliances. In this case it would be one toilet and one sink tying into the line with one toilet, one sink and 2 tubs. Would a 3" suffice?
Then ht big question, is it legal to throttle the hacker, and the county??
Old 02-26-2012, 09:31 PM   #7
Rewards Points: 636
try this it takes a little to figure out how to click then click lower group
http://publicecodes.citation.com/ico...2012/index.htm
Old 02-27-2012, 07:52 AM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 996
[quote=fireside;864384]Yellow glue- I was thinking home depot- but that would be orange
orange cpvc
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-27-2012, 02:45 PM   #9
Rewards Points: 150
Yellow ABS glue is the standard in Canada. It would be odd for me to see any other colour.
psilva8 is offline   Reply With Quote
Old 02-27-2012, 07:36 PM   #10
Rewards Points: 582
thanks standard in my area pa is black...
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
