Vent Distance - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2011, 07:33 PM   #1
Vent Distance
Hi,
Is there a specific distance that a toilet and bathtub need to be from the main vent out of the roof? Or as long as everything is connected to the main sewage drain with that vent it's ok?
I was looking to change over the plumbing in the basement to PVC and do away with the old cast iron pipes. The only place I can relocate the 4" vent stack is in the middle of the house which will leave me about 12 feet form the toilet and tub connections. Is that ok?
Thanks in advance!
Yoshi52 is offline   Reply With Quote
Old 01-11-2011, 08:05 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
Most likely not okay
Check what code your municipality uses, and do a web search for "Critical Distances" as per that code. I don't know the exact distances you need, but 12' is almost certainly too far.
adpanko is offline   Reply With Quote
Old 01-13-2011, 06:49 PM   #3
Question
I checked the code for my area and we use the 2009 IPC. I believe I read it right but I just wanted someone to verify that for me if possible.
I believe it states in the code that if running a 4" drain....you can have a 12' arm to the main vent stack. Does anyone know if this is correct?
Old 01-13-2011, 10:58 PM   #4
Yoshi
You are correct.
Work4living is offline   Reply With Quote
Old 01-14-2011, 06:31 AM   #5
Licensed Master Plumber
Toilets not a problem but you can only run 6' from the tub to the lateral
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 01-14-2011, 07:33 AM   #6
Actually tub distance is dependant on the line size.1-1/2" can run 6'.2" can run 8'
Minimum distance from furnace vent to bathroom fan vent? pttcc HVAC 1 08-25-2010 09:54 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
distance requirements for range vent chalkline HVAC 2 12-08-2008 02:28 PM
Dryer vent and AC compressor - min. distance? RDS HVAC 5 05-04-2008 07:50 AM
