Vent Directly Between Trap And Drain, Or Not? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2010, 04:44 PM   #16
of coarse after 45 years as a plumber i knew it and i knew someone would answer it on the forum
Bad Meteorology:
The water in a sink (or toilet) rotates one way as it drains in the
northern hemisphere and the other way in the southern hemisphere.
Called the Coriolis Effect, it is caused by the rotation of the Earth.
So what do you tell your students.
The direction of rotation in draining sinks and toilets is NOT determined by the rotation of the Earth, but by rotation that was introduced earlier when it was being filled or subsequently being disturbed (say by washing). The rotation of the Earth does influence the direction of rotation of large weather systems and large vortices in the oceans, for these are very long-lived phenomena and so allow the very weak Coriolis force to produce a significant effect, with time.
http://www.ems.psu.edu/~fraser/Bad/BadCoriolis.html
HARRY 65 is offline   Reply With Quote
Old 07-18-2010, 05:34 PM   #17
Rewards Points: 101
Bad Meteorology:
The article you pointed out falls under the affect of turbulence where yes you can force a draining sink to go the other way. But if you take a sink that was filled and left to settle with the water off and then remove the plug, it will be determined by the coriolis effect. Your attempt at trying to "one up" people by asking a question you thought you knew the answer to failed. You should try another topic when doing that.
wvphysics is offline   Reply With Quote
Old 07-18-2010, 05:37 PM   #18
Electrician
Proby's Avatar
I was thinking the same thing
Proby is offline   Reply With Quote
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 01:40 PM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-17-2008 12:11 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
