Vent For Basement Bathroom Group - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2010, 11:44 AM   #1
Vent for basement bathroom group
Hello all - am currently finishing my basement and have a question I was hoping the experts could help me with.
I have a bathroom that is stubbed for a sink, toilet, and shower. The shower has a square drain pan, with another pipe sticking out of the floor (assuming shower/toilet vent?) about 12" behind it. Then there is a toilet drain and then on the other side of that a lav drain.
I also have a vent pipe in the ceiling that is capped off which is directly above the "shower vent" that is sticking out of the floor beside the shower pan.
I know that I need to run the shower vent up to this vent connection in the ceiling, however I'm wondering if I need to also vent the lav drain up there too. Or is the lav somehow vented through the shower vent in which case I just use the lav pipe as a drain and that's it?
I guess I could go on the safe side and just vent both the lav and the shower pipes up to the ceiling vent connection, but just thought I'd check as it would save some time.
Thanks in advance for any advice!
Chad
chadmills is offline   Reply With Quote
Old 10-29-2010, 04:03 PM   #2
You need to vent both - undiminished in size - and they should be 2" I.D. minimum. One of those (probably the lavatory drain) is also serving as a "wet vent" for the toilet.
Ishmael is offline   Reply With Quote
2 Bathroom fans to 1 roof vent? theatretch85 Kitchen & Bath Remodeling 13 12-15-2013 09:25 AM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
