Vent Back Into Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2011, 10:28 AM   #1
Rewards Points: 93
Vent back into stack
Is it alright to vent back into the stack in the basement? I would go to the highest point of the stack in the basement and vent back using a 3"x1.5" Y.
simonb is offline   Reply With Quote
Old 12-12-2011, 11:49 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
I never do. Its not allowed per UPC
Old 12-12-2011, 12:25 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Why would you want to do that?
titanoman is offline   Reply With Quote
Old 12-12-2011, 12:36 PM   #4
Rewards Points: 93
Because there is no option for me to vent. I have to run a line which means opening walls up.
Old 12-12-2011, 12:39 PM   #5
Disabled wood vet
titanoman's Avatar
Then I would do it exactly your way, although you could probably sneak a pipe in there without tearing a wall apart. Is there insulation in it?
Old 12-12-2011, 01:15 PM   #6
Rewards Points: 93
The inside walls dont line up, so i would have to use an exterior wall.
Old 12-12-2011, 03:38 PM   #7
Rewards Points: 2,210
Can you go up a wall, across a ceiling and up a wall?
Only need about a 1' square hole at top and bottom to get drill in to drill the hole with a right angle head. Can rent one if needed.
Does the main stack not run straight up from where you would join into it?
Could you go right up beside (or near) it and join into it in the attic or even in the wall above the highest fixture?
mae-ling is offline   Reply With Quote
Old 12-12-2011, 08:49 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 990
What are you venting? if its not a heavy fixture load you may be able to self vent loop.
Javiles is offline   Reply With Quote
Old 12-12-2011, 10:43 PM   #9
Rewards Points: 582
no its not alright.... and would be a code violation in most places.
Plumbing vent (Stack) leak lizziefl Plumbing 26 02-11-2012 09:11 PM
replacing parts of cast iron vent stack amakarevic Plumbing 7 03-30-2011 04:41 AM
Vent Sure High Performance Slant Back Roof Vent Alto Roofing/Siding 4 07-04-2010 01:06 PM
can stack vent turn 90 degrees? hohadcr Plumbing 6 03-16-2010 07:45 AM
vent stack for drain Bob Banas Plumbing 1 01-18-2009 10:26 PM
