Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2013, 01:59 PM   #1
Rewards Points: 202
Vent
Is this ok for vent. 90 goes vertical up to attic. The cap closet to frame is for future laundry vent tie-in. The pipe going back goes to the fixtures being vented.
benleef is offline   Reply With Quote
Old 06-02-2013, 02:00 PM   #2
Rewards Points: 202
Sorry forgot pictures.
Old 06-02-2013, 06:49 PM   #3
Rewards Points: 2,036
No dry flat vents allowed in IPC. A vent cannot go horizontal until it is a min of 6 inches above the flood level rim of the fixture served.
Old 06-02-2013, 07:06 PM   #4
Rewards Points: 202
It's 6" above the flood rim. I've decided to do a double elbow fitting there instead
Old 06-02-2013, 07:08 PM   #5
How could that be since your still below the floor?
The Following User Says Thank You to Ghostmaker For This Useful Post:
gregzoll (06-02-2013)
Old 06-02-2013, 07:16 PM   #6
Rewards Points: 202
It is a
Old 06-02-2013, 07:17 PM   #7
Rewards Points: 202
It is a basement bathroom
Old 06-02-2013, 07:48 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 802
If it's a dry vent, it would pass UPC inspection. UPC does not require slope or drainage fittings on dry vents.
But, as a personal thing, I would use a 90 instead of the tee and place the tee, or a wye between the 90's
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 12:34 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
