Old 10-20-2012, 02:22 AM   #1
Vaseline for 11/4" vinly tubing / barbed fitting?
I'm having a hell of a time getting 1 1/4" vinyl tubing over some barbed fittings. I put the tubing in hot water, but it's still really hard to get it on the barb. Would using Vaseline be recommended? It wouldn't hurt the tubing or connection over time?
Is there a better way to get the hose on the barb? Take steroids and join a gym? :P
tibberous is offline   Reply With Quote
Old 10-20-2012, 10:09 AM   #2
What is it your trying to hook up doing it that way?
I've used silicone grease so it will not effect the tubing.
Old 10-20-2012, 10:19 AM   #3
That's probably a better idea, I actually have a tube of silicone grease for my water filter.
Old 10-23-2012, 08:08 PM   #4
You might want to purchase a heat gun ( at $25 to $100), or try using a hair dryer.
Ron S. is offline   Reply With Quote
Old 10-23-2012, 08:16 PM   #5
Yeah, that doesn't work for ****. Bucket of hot + silicone grease is by far the best way I've found; easy at first but kills your chest after you do a few.
Looking for 3/4" rubber tapered barbed pipe fitting for two female PVC pipes matthewadams Plumbing 14 09-11-2012 05:42 PM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 07:47 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
