Vanity Waste Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2012, 05:08 PM   #1
Vanity Waste Line
Can anyone tell me if it would be OK to plumb a vanity waste line into this PVC. The larger pipe on the right is the vent to the roof.
Thank you in advance!
steve91386 is offline   Reply With Quote
Old 06-23-2012, 05:12 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
That pipe looks like a vent from a fixture on the floor below. If that is what it is, no you cannot add a drain to that line. That would create a wet vent.
You may be able to plumb a drain into the larger pipe. Need more info on what is below this floor.
Coastal South Carolina
Old 06-23-2012, 05:13 PM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
that's also a vent, is this on a first or second floor
wctekkk is offline   Reply With Quote
Old 06-23-2012, 05:20 PM   #4
Second floor. Essentially, I pulled the old vanity out which had the side panel cut away to allow access for the drain that was originally plumbed in. The vanity which the misses has to have requires that the waste line come directly out from the back of the wall between the hot and cold copper lines.
Any suggestions on how to tackle this scenario would be greatly appreciated!
Main Line Clog Master Brian Plumbing 46 09-06-2012 08:38 PM
Waste ejection line tie-in jmarro Plumbing 4 04-22-2011 12:29 AM
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 09:55 PM
Basement Rough in PSULion55 Plumbing 1 02-06-2010 12:44 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
