-   -   Vanity Waste Line (http://www.diychatroom.com/f7/vanity-waste-line-148029/)
steve91386 06-23-2012 05:08 PM
Vanity Waste Line
Can anyone tell me if it would be OK to plumb a vanity waste line into this PVC. The larger pipe on the right is the vent to the roof.
Thank you in advance!
https://lh3.googleusercontent.com/-t...05-k/photo.jpg
rjniles 06-23-2012 05:12 PM
That pipe looks like a vent from a fixture on the floor below. If that is what it is, no you cannot add a drain to that line. That would create a wet vent.
You may be able to plumb a drain into the larger pipe. Need more info on what is below this floor.
wctekkk 06-23-2012 05:13 PM
that's also a vent, is this on a first or second floor
steve91386 06-23-2012 05:20 PM
Second floor. Essentially, I pulled the old vanity out which had the side panel cut away to allow access for the drain that was originally plumbed in. The vanity which the misses has:thumbsup: to have requires that the waste line come directly out from the back of the wall between the hot and cold copper lines.
Any suggestions on how to tackle this scenario would be greatly appreciated!
https://lh6.googleusercontent.com/-v...25281%2529.JPG
https://lh4.googleusercontent.com/-a...oto%282%29.JPG
