Vanity Shelf Interfering With Trap Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2013, 08:45 PM   #1
jkk
Rewards Points: 233
Vanity shelf interfering with trap install
With a new vanity 'installed', there is only ~2" from the shelf to the bottom of the drainpipe coming out of the wall. Not enough room to fit a standard trap installation.
It seems like I need to glue in some pieces that slope downwards from the trap to the wall pipe. Is that feasible?
jkk is offline   Reply With Quote
Old 02-12-2013, 08:50 PM   #2
Rewards Points: 13,296
I've had to cut a rectanguler shape hole in the shelve.
Javiles (02-12-2013)
Old 02-12-2013, 09:12 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
Your trap outlet needs to be at the level as the pipe in the wall- so as Joe said, you need to cut a hole. Also, you get about 3" of swing in a trap, so you need to move the sink over a tad or put a 45 on the drain arm
Old 02-12-2013, 09:44 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Looks like you might as well open the wall up and adjust the elevation and the horizontal arrangement of the drain. That's what I would do. I hate cutting into cabinets.
Journeyman Plumber
Old 02-12-2013, 09:53 PM   #5
jkk
Rewards Points: 233
Well there's another sink on the other side of the wall, so changing the drain in the wall is considerable work. What is wrong with using 45s to slope down from the trap to wall?
Old 02-12-2013, 10:10 PM   #6
Doing it myself
Alan's Avatar
It puts your vent below the trap arm which causes siphoning of the trap.
Journeyman Plumber
Old 02-13-2013, 10:50 PM   #7
Rewards Points: 940
I'm confused about this. Can you have a vent above the trap?
I mean, what is the difference between coming off the trap, dropping down a bit, then going into the wall (where it surely drops immediately), and going directly into the wall (where it surely drops immediately)?
How does siphoning occur unless the vent is before the trap?
I've always been told you want the vent as close to the trap as possible, and there are some permitted maximums. Obviously, a vent 30' from a trap isn't as good as one 3" away.
So if the vent is 6" below the trap, and the water wants to pull on the trap water, the vent won't stop this suction?
cleveman is offline   Reply With Quote
Old 02-13-2013, 11:01 PM   #8
Doing it myself
Alan's Avatar
No, because water seeks it's own level. Picture a piece of pipe on grade.
Now picture water in the pipe. The water is level in the pipe because again, water seeks it's own level.
As the pipe gets longer, soon you see that on the downhill end of the pipe, the water level is reaching the top of the inside of the pipe. Once this happens, the air is not allowed into the horizontal pipe anymore. It pulls air through by siphoning the trap.
Same thing happens when the trap arm is offset vertically. Someone here has posted a diagram here before of this scenario, and I have a book that shows it. Hopefully you understand what i'm saying.
Journeyman Plumber
Old 02-13-2013, 11:04 PM   #9
Doing it myself
Alan's Avatar
Here's a diagram
http://www.billbblog.com/Content/ima...fixtureArm.jpg
Journeyman Plumber
Old 02-13-2013, 11:20 PM   #10
Rewards Points: 940
OK, I get it.
You must be worried about situations where the vent is out of code. In my experience, a lav sink drains into the wall, where it meets a tee. The tee is the vent, so the trap is about a foot from the vent.
I was also taught to drop a toilet into a tee or elbow with a 2" coming off it for the vent.
And typically the bathtub is about 30" from the toilet.
Anyway, thanks for the clarification.
Old 02-14-2013, 10:10 AM   #11
Doing it myself
Alan's Avatar
No, like I said if the vent is below the trap arm for instance how the OP is talking about offsetting his trap arm UPWARDS to clear a shelf, the trap can siphon. It really has nothing to do with the vent.
Journeyman Plumber
Old 02-14-2013, 10:19 AM   #12
jkk
Rewards Points: 233
Per the diagram, it is allowed to have some minimal pitch. Is that correct?
Old 02-14-2013, 09:31 PM   #13
Doing it myself
Alan's Avatar
The diagram is sketched as 1/4" per foot slope. That is why your trap arm maximum length increases with pipe size. If you slope your pipe steeper, the theory is that your maximum length should decrease. Most of the time under vanities we don't have this issue with length however.
Journeyman Plumber
Old 02-14-2013, 09:44 PM   #14
jkk
Rewards Points: 233
Yes, so for a 1' length with 1.5" pipe, I can have 1.5" of drop. Right?
Old 02-14-2013, 09:46 PM   #15
Doing it myself
Alan's Avatar
In theory, yes, but that is too steep to achieve over a 1 foot section without using fittings.
Journeyman Plumber
Vanity space for shut-offs and drain / trap mitchell39 Plumbing 1 06-20-2012 01:18 AM
Vanity Tight Fit Chemist1961 Remodeling 2 01-10-2009 03:30 PM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 01:01 AM
vanity sink install aulii1 Plumbing 2 11-28-2008 01:43 PM
Vanity install tate16t Remodeling 3 09-13-2008 08:48 AM
