Vanity P-Trap Weird Configure - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 11:32 AM   #1
Rewards Points: 214
Vanity P-Trap weird configure
SHould the vanity drain look more like the setup for the laundry?
I think I would just have to lengthen the tailpiece and attach a 45 to the stub out to be able to match the wall bend to the p-trap.
rosem637 is offline   Reply With Quote
Old 05-12-2013, 11:49 AM   #2
Rewards Points: 528
They are both fine.
What is the problem with either?
framer52 is offline   Reply With Quote
Old 05-12-2013, 12:58 PM   #3
Rewards Points: 322
I can't tell if its the camera angle, but it looks like you have enough room to shorten up the drain extension to get the horizontal piece at a better angle.
tribe_fan is online now   Reply With Quote
Old 05-12-2013, 01:16 PM   #4
Rewards Points: 214
Originally Posted by framer52 View Post
They are both fine.
Nothing particular. Just wondering if a home inspector might say the vanity one is not correct.
you mean on the vanity the horizontal piece between the two 90's?? It does have pitch toward the p-trap. Might of been angle of camera.
Old 05-12-2013, 01:40 PM   #5
Rewards Points: 1,684
The vanity one will work bet it is an example of PP plumbing. PP Piss poor
Old 05-12-2013, 02:27 PM   #6
Rewards Points: 528
Both are OK, don't frets.
Old 05-12-2013, 10:41 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Vanity setup is missing a compression nut.
Technically you have a running trap on the vanity.... tailpiece should remain vertical, at least last I checked, which means 45 degrees from the vertical or less.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (05-13-2013)
Old 05-13-2013, 07:40 AM   #8
Rewards Points: 214
I did notice that. Also there is a slip joint nut not on the piece that goes into the trap adaptor. How can two slip joint nuts be missing but no leaks?
Vanity P-Trap weird configure-101_9912.jpg   Vanity P-Trap weird configure-101_9920.jpg
Old 05-13-2013, 03:55 PM   #9
maybe they glued them
Vanity shelf interfering with trap install jkk Plumbing 21 02-17-2013 03:25 AM
Vanity space for shut-offs and drain / trap mitchell39 Plumbing 1 06-20-2012 01:18 AM
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 03:17 PM
Enlarging vanity and P trap problems wildcard585 Plumbing 2 05-10-2011 08:34 AM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 02:12 PM
