-   -   Vanity P-Trap weird configure (http://www.diychatroom.com/f7/vanity-p-trap-weird-configure-179370/)
rosem637 05-12-2013 10:32 AM
1 Attachment(s)
SHould the vanity drain look more like the setup for the laundry?
I think I would just have to lengthen the tailpiece and attach a 45 to the stub out to be able to match the wall bend to the p-trap.
framer52 05-12-2013 10:49 AM
They are both fine.
What is the problem with either?
tribe_fan 05-12-2013 11:58 AM
I can't tell if its the camera angle, but it looks like you have enough room to shorten up the drain extension to get the horizontal piece at a better angle.
rosem637 05-12-2013 12:16 PM
Originally Posted by framer52 (Post 1177719)
They are both fine.
Nothing particular. Just wondering if a home inspector might say the vanity one is not correct.
you mean on the vanity the horizontal piece between the two 90's?? It does have pitch toward the p-trap. Might of been angle of camera.
Ghostmaker 05-12-2013 12:40 PM
The vanity one will work bet it is an example of PP plumbing. PP Piss poor
framer52 05-12-2013 01:27 PM
Both are OK, don't frets.
Alan 05-12-2013 09:41 PM
Vanity setup is missing a compression nut. :huh:
Technically you have a running trap on the vanity.... tailpiece should remain vertical, at least last I checked, which means 45 degrees from the vertical or less.
:whistling2:
rosem637 05-13-2013 06:40 AM
2 Attachment(s)
I did notice that. Also there is a slip joint nut not on the piece that goes into the trap adaptor. How can two slip joint nuts be missing but no leaks?
DannyT 05-13-2013 02:55 PM
maybe they glued them
