Old 11-12-2007, 03:35 PM   #1
Valve to the toilet is not working
So our Mansfield toilet was running, and I installed a new flush valve, but it took me a few days just because I needed to get out and get the part. I shut the water off so it would not continue to run and no problems there. After installing the new flush valve I fill the tank back up and it seems to be fixed but to make sure I turn the water back off and come back in a few hours to see if the water level went down at all. It had not so I assume I fixed the problem. So I go back to turn the water on and nothing at all no noise no water running nothing...
Any ideas
TIA
swirv is offline   Reply With Quote
Old 11-12-2007, 03:44 PM   #2
47_47's Avatar
If the tank was full when you turned the water back on, you tank is full and you will not hear any water running. Did you flush the toilet and see if it fills?
47_47 is offline   Reply With Quote
Old 11-12-2007, 03:50 PM   #3
Yeah I flushed and there is little to no water left in the tank so it should be refilling
Old 11-12-2007, 04:18 PM   #4
jproffer's Avatar
Check to make sure the float isn't stuck in the up position.
New flush valve clogged with some kind of debris. (something fell into the tube while you were changing it)
Defective flush valve (unlikely but possible I suppose)
Just brainstorming. If it was me I would take it back apart and find the last place that I did have water..the next thing in line is the problem.
jproffer is offline   Reply With Quote
Old 11-12-2007, 04:18 PM   #5
47_47's Avatar
Is the float on the fill valve stuck in the up position or did it drop?
Old 11-12-2007, 05:43 PM   #6
It dropped, and is in it's proper position
Old 11-12-2007, 05:45 PM   #7
Well it's weird because once complete it was working. Put it together and filled the tank by turning the valve Then shut it off for those 2 hours to make sure the waterline did not drop, which it did not. So it was then when I turned it back on. I flushed and it never refilled
Old 11-12-2007, 07:54 PM   #8
Send a message via AIM to Marlin
Shut the valve off, remove the supply line and slowly open the valve. Do you get water?
No, you need a new speedy valve.
Yes, something is wrong with your new flush valve
Marlin is offline   Reply With Quote
Old 11-12-2007, 09:54 PM   #9
Thanks will be looking into a new speedy valve hopefully this fixes it
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 04:41 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 04:58 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
