Old 05-21-2012, 09:36 AM   #1
Valve Leaking through diverter - Low Hot Water
Installed my new symmonds valve. It leaks through the diverter. I took it apart and saw a washer, looked fine (brand new). Any thoughts?
And the water doesn't get hot, only warm.
Thanks for the help.
Coop
coopns is offline   Reply With Quote
Old 05-22-2012, 03:00 AM   #2
Looks like a shower only. Where is the diverter leaking? is the water coming to the mixing vale on the left side hot (touch it). There may be a temerature limit stop on the front of the valve. Try loosening or tightening the brass screw on the front of the valve.
sanec1 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Leaking Main Water Valve, can I just replace "innards"? Minjin Plumbing 6 09-22-2011 09:05 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
