Valve Broke On Well Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-15-2013, 11:11 AM   #1
Rewards Points: 768
Valve Broke on Well Line
We have a well with 3 hydrants and one line run to a horse waterer (the well only supplies water to our barn, not our house). The shutoff on the horse waterer broke, so I had to shut of the main line at the well pump.
The line going to the waterer is a rubber tube with a watts brand shut off. Since the valve broke off, I'm wondering what all needs to be replaced. Is there a copper stem that is placed inside the rubber line? Just wondered if anyone has come across this?
cibula11 is offline   Reply With Quote
Old 04-15-2013, 11:32 AM   #2
Rewards Points: 12
Please post a pic.
Dan
djlandkpl is offline   Reply With Quote
Old 04-15-2013, 11:42 AM   #3
Rewards Points: 768
Originally Posted by djlandkpl View Post
Please post a pic.
I can't now, but I'll try later.
The 1" hose (line) looks to be clamped onto the valve...just not sure how to remove the broken valve assembly so I can replace it.
Old 04-15-2013, 01:32 PM   #4
Rewards Points: 13,276
And where not sure how to suggest something without seeing what you have.
Old 04-17-2013, 03:43 PM   #5
Rewards Points: 768
Here are three pics. The one is of the top part of the valve assembly that broke off. As you can see the valve sits inside of the black hose and is clamped. Hope this helps.
Old 04-17-2013, 06:19 PM   #6
Rewards Points: 12
I can't tell pipe diameter from the pics. It also look like the fitting in pic #1 unscrews. I believe you need one of these.
http://www.lowes.com/pd_331196-61002...AID=1397405407
Dan
Old 04-18-2013, 11:16 AM   #7
Rewards Points: 768
I'm not sure if the valve is threaded or not. It appears so as there is a nut of some kind on the bottom of the fitting, but when I turn it, the whole valve assembly turns with it. There's not much room to clamp another wrench onto the top of the broken valve to get any leverage.
Old 04-18-2013, 11:22 AM   #8
Rewards Points: 768
Here's a larger pic. Not sure if it will help....or maybe it's not larger. sorry
Old 04-18-2013, 11:46 AM   #9
Rewards Points: 12
The nut part circled in red it part of the valve and the valve should turn with it. Just make sure the pipe is not turning.
Dan
Screw hole on shower valve broke off Amymestas Plumbing 5 07-16-2012 11:24 AM
Pressure Reducing valve and location irrigation branch line ironqqq Plumbing 3 07-14-2012 02:53 PM
Leaking ball valve in a gas line jshansen32 Plumbing 17 07-13-2012 10:58 AM
range gas line - is this OK? denemante Plumbing 15 12-17-2011 05:21 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
