Valve Blow Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2009, 08:36 PM   #16
GC/Master Plumber/Mech
Rewards Points: 560
Check out this link it shows PB valve...Hum...They look like the cold side
Hum........
http://www.acehardwaresuperstore.com...412_41204.html
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-19-2009, 08:39 PM   #17
dtzulu
dtzulu's Avatar
plumber 101, i have to agree with you about the pipe being polybutylene, because the cement i tried will not work on that type of pipe, it's listed for CPVE, PVC, and another that i can't recall off hand. but when i scrapped that mode and went to the compression connections everything seemed to work fine, so far i stress. the guy at the plumbing supply store i went to said that the compression valves he sold me were the one's i needed, so i hope he steered me in the correct direction.... thanks for the heads up.
dtzulu is offline   Reply With Quote
Old 09-19-2009, 08:45 PM   #18
Rewards Points: 560
The problem is with how the valve end that compress is designed to compress.
A stop or valve with a ferrel used to compress against a metalic or metal pipe. When used with plastic there needs to be an insert. But PB is total IMHO different. As time goes by the compressiom can weaken and collapes.
My suggestion to you is to get a 1/2" male adapter shark bite and then in stall a 1/2" npt / 3/8 compression valve. The Shark bite will slide over the pipe and seal without worries. Tons beter than what you have now.
Zoom
Old 09-19-2009, 09:15 PM   #19
dtzulu
dtzulu's Avatar
plumber 101, i went through the link and the valve i used was the Zurn/Qest angle stop shut off valve. it is a compression connection and is rated for polybutylene, CPVC, and copper tubing. my wife noticed a very small amount of dampness @ the valve, which i didn't see/feel this morning. so, something is still amiss.
Old 09-19-2009, 09:45 PM   #20
dtzulu
dtzulu's Avatar
Thumbs up
i see your point...
plumber 101,
i printed out the post and the picture you sent about the connection i should use. after looking at the configuration i have going on, and reading your instructions, i do believe that is the way to go. it just makes more sense. thanks so much for your guidance, and tomorrow i'll be heading to Ace hardware to pick up what i need, list and pics in hand. thanks again, and if you ever have any property line/survey questions i'll be happy to help you out!! thanks again, david j. thompson, stone mountain, georgia.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Air Compressor Blow Off Valve Help shoeheel Tools 1 12-12-2008 04:21 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
