Valve Blow Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2009, 04:00 PM   #1
dtzulu
dtzulu's Avatar
valve blow out
g'day forum,
ok, i noticed a leak under my bathroom sink. looking closer both the hot and cold water shut off valves were leaking. these are old valves, made from PVC i would guess. so i went to HD and brought new chrome angle multi-turn valves. i had to cut the connection from the water line feed coming from behind the wall to under the sink. i had no problems connecting the line up to the faucets, but had to use the Oatey All Purpose Cement to weld the connection into the new valve. i followed the directions and waited for about an hour before i turned back on the water. it held for about 30 minutes before i had a major blow out and a huge wet mess to clean up. i asked a friend about it (he's not a plumber but does contract home work) and he told me that if the pipe is not PVC but the other grey plastic pipe, i can't recall what he said the name was, but anyway he said that the all purpose cement would not work on that type of plastic pipe. he said i should maybe try the Oatey Purple Primer and then the cement and it might hold. any thoughts or suggestions?
valve blow out-im001748.jpg   valve blow out-im001749.jpg   valve blow out-im001750.jpg
dtzulu is offline   Reply With Quote
Old 09-16-2009, 08:06 PM   #2
Rewards Points: 171
are you sure the water lines are not PEX lines. If they are you cannot glue the fittings on.
paul100 is offline   Reply With Quote
Old 09-16-2009, 08:39 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Post a pic so we may ID the type of pipe you have
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-16-2009, 08:49 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Just get some compression angle stops and a couple of plastic ferrules and stiffeners. Could be you have CPVC, Qest, PEX or who knows what. Whatever you have, compression stops should work just fine
JDC is offline   Reply With Quote
Old 09-17-2009, 07:45 AM   #5
dtzulu
dtzulu's Avatar
ok, i have posted pics of the pipe. i would hate to call in a plumber to replace simple valves, (not so simple it would seem!) but i'm at the point of just calling in the experts. but i really want to learn to do simple things like this on my own. call the experts for the really big jobs. thanks, dave.
Old 09-18-2009, 11:55 AM   #6
dtzulu
dtzulu's Avatar
well, it seems that all i needed were the compression connections. once i switched to those, everything worked fine, and not a drip from the hot or cold water lines. thanks for the help JDC!! david.
Old 09-18-2009, 07:58 PM   #7
If those are grey plastic they are poly and you better have valves designed to go on poly pipe or you will come home to a flooded house one day.
plumber Jim is offline   Reply With Quote
Old 09-18-2009, 08:20 PM   #8
dtzulu
dtzulu's Avatar
Unhappy
will the compression connects not hold?
i used the compression type connections and so far it seems to be holding. when i tried the oakley all purpose cement that's when the connection blew loose. the guy at the plumbing supply store i went to said that for the type of pipe i have that the compression connections for the valves should hold.... now i'm worried
Old 09-19-2009, 12:20 AM   #9
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
As long as you used plastic ferrules you'll be fine.
Old 09-19-2009, 09:57 AM   #10
Civil Engineer
Rewards Points: 4,700
That pipe looks like it might be polybutylene. There is a long history of trouble with polybutylene pipe and fittings, including lawsuits.
PEX stands for cross linked polyethylene, a totally different material than polybutylene, but I have never seen grey PEX (perhaps a plumber can chime in here, not saying it doesn't exist).
I have seen grey PVC (polyvinyl chloride) pipe, and grey CPVC (chlorinated polyvinyl chloride), and I do not know how to distinguish PVC or CPVS from polybutylene, unless of course the pipe is marked. Perhaps someone on this forum knows of a test.
Old 09-19-2009, 10:02 AM   #11
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 822
Man, I really hope that's not PVC electrical conduit. But it sure looks like it.
Aggie67 is offline   Reply With Quote
Old 09-19-2009, 10:23 AM   #12
Ifthat is grey polybutylene then using regular compression stops isn't the way to do it and will result in a leak at some point. is the pipe grey? is it flexible? if yes to both thats what you have. Oh when i say flexible i mean its not as stiff as regular pvc.
Old 09-19-2009, 08:16 PM   #13
dtzulu
dtzulu's Avatar
Question
at this point i'm REALLY confused....
well, (finally tearing myself away from all the great football games today) what i can state is this... first, after two days, i still don't have any leaks of drips from the valve connections. second, that i highly doubt that it is electrical conduits, since nothing but H2O has ever come from that pipe, unless the contractor who did the plumbing when my house was built was really shady. and third, when i went back this morning to check for leaks, i can say that the pipe is not flexible but stiff. i was told that it was not PVC because if it was the Oakley All Purpose Cement would work, plus that was listed on the label as one of the types of pipe it would work on. so i surmise that it is PBV (Polybutylene), and the compression valves should do the trick. thanks, and if i'm amiss please let me know. but so far, so good. David J. Thompson... Land Surveyor, yes... Plumber, no.
Old 09-19-2009, 08:25 PM   #14
Rewards Points: 560
It to me looks like PB polybutylene pipe. If you notice the cold valve is what I think is for PB. I agree with Plumber Jim get the right valve.
While you feel secure that in two days no leaks, just wait until you and your family are at moms for x-mas or something else and you come home to complete disaster. My advise is tow things 1. fix it right and 2. Have your insurance agent on speed dial
Old 09-19-2009, 08:27 PM   #15
dtzulu
dtzulu's Avatar
Unhappy
what?
to PlumberJim,
from what you have posted, my pipes should be PVC, because it is stiff. if so, wouldn't the all purpose cement have held? i tried twice using that and both times the connection blew apart after about thirty minutes. however, when i switched to the compression connectors, everything held just fine... any thoughts on what i should try? note, as i said in my other post, it's been two days and there are not drips or leaks, but i don't want to come home from work and find my down stairs a squishy mess...
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Air Compressor Blow Off Valve Help shoeheel Tools 1 12-12-2008 04:21 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
