Vally Bathroom Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2010, 09:15 AM   #1
vally bathroom faucets
How do I repair a leaking bathtub/shower faucet? Home was built in 1988, with Vally fixtures
Geneo is offline   Reply With Quote
Old 03-23-2010, 09:34 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
What brand/model/type is the unit? Is the shower HEAD leaking, or the on/off hot/cold valve?
The head is an easy fix. Simply unscrew and replace with better or attempt to fix leak.
The valve, it would be best/easiest if you could post a picture. Many different types out there, but most will just need a new washer and/or sometimes the cartridge needs to be changed out.
DM
Old 03-23-2010, 10:14 AM   #3
Thanks for the reply.... the faucet is made by Valley and is a one handle faucet, am trying to remove the bonnet nut assembly but ether its too tight or I'm turning it the wrong way also need to know what part I need to repair.. how do I attach a photo when it looking for a "URL"???
Old 03-23-2010, 11:08 AM   #4
the Musigician
Hit "post reply" right under this post, NOT "quick reply". The type the message. Under that section, you will see "manage attachments". Click there to upload directly from your drive to your post.
Hit "submit" when upload shows.
DM
Old 03-23-2010, 11:26 AM   #5
Am trying to remove the bonnet nut (see Attached Photo) in order to fine out what part I need to repair the leak. ether its too tight or I'm turning the wrong way. Am using a pipe wrench, and I don't want to break it. any help would be nice....Thanks, Gene
Old 03-23-2010, 11:52 AM   #6
the Musigician
It looks like that outer ring SHOULD come off with a pipe wrench....? hmmm.
A 20+ yr. old unit should probably be replaced anyways.... lol I'd just go for it.
DM
Old 03-23-2010, 11:53 AM   #7
the Musigician
Look underneath and be sure there isn't an allen wrench head or normal screw locking it in place.
DM
Old 03-23-2010, 11:58 AM   #8
Thanks...with a little more effort I got it off. Now with assembly in my hands, do I replace the whole cartridge or just the O-rings?????
Again, thanks
Gene
Old 03-23-2010, 12:03 PM   #9
the Musigician
Are the O-rings broken or cracked? If so, it MAY fix the problem, and certainly will be the cheapest way to go. So go that route first.
Worse case scenario, you have a couple spare O-rings for the new one....lol
DM
Old 03-23-2010, 01:45 PM   #10
replaced the cartridge and all's well....no leak. Thanks for all the help.
T/C
Thank you
Gene
Old 03-23-2010, 01:50 PM   #11
the Musigician
Glad to help, it's what we live for here.
Po)
DM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Best quality bathroom faucets for the money tomyco Plumbing 6 03-09-2009 04:45 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
