Valley Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2007, 09:55 AM   #1
I am installing new valve stems in my shower, I have bought all new parts that are the same as I have taken out. The spring in the back of the valve stem will not seat fully into the valve. Is there a trick to getting this peice in? Right now when I turn on the water to the house water flows slowly from the spout.
lost is offline   Reply With Quote
Old 06-23-2007, 10:17 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Did you put the garments over the top of the springs?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 06-23-2007, 10:19 AM   #3
if you mean the black rubber thing that goes over half the spring, yes
Old 06-23-2007, 10:26 AM   #4
Journeyman Plumber
When you put them over the springs did the edges of it recess into the seat area?
Old 06-23-2007, 10:33 AM   #5
no, it sticks out a about 1/16 or so, i tried to push it further but it just comes right back out
Old 06-23-2007, 10:39 AM   #6
Journeyman Plumber
Thats how they work, if you have the old springs use them and the new rubber ends, see if that works, did a shower valve the other day, the springs were not the same, so use old ones with new washers and that worked, if the springs were the same then is it possible you damaged one of the rubbers when you installed them? Pull them and see if there ok.
Old 06-23-2007, 10:41 AM   #7
i will try that. Does the rubber part fit onto the spring where it would semi hard to pull off or does it just sit on top and could fall off i turned it upside down?
Old 06-23-2007, 10:43 AM   #8
Journeyman Plumber
Sits over the end of the spring
Old 06-23-2007, 10:48 AM   #9
one more thing, is it suposed to be easy to put the spring in or is there some trick that i am missing
Old 06-23-2007, 10:55 AM   #10
Journeyman Plumber
The spring sits in there loosely the rubber holds the the spring in place, after it's in you should be able to push in on them and feel them as they push inward then when letting go they will return to there position, they will feel spongy when seated properly.
Old 06-23-2007, 06:59 PM   #11
Union HVAC Tech.
Also look to see if there are deep scratches on the ball where it meets the seats.
bigMikeB is offline   Reply With Quote
Old 06-24-2007, 07:10 AM   #12
I cant tell if there are scratches. I tried putting the old spring back in cause it looked like it was a bit shorter than the new one but it still didnt seat right. When i took the spring out the rubber thing fit if perfect. So I know this isnt a perminent fix but I made the new spring a bit short by cutting a little off to get it in till I can make it back to the faucet store I got the springs from. I still have more new springs if you guys can think of something I doing wrong.
Old 06-24-2007, 07:53 AM   #13
Journeyman Plumber
Is the springs your using cone shaped or straight?
Old 06-24-2007, 09:16 AM   #14
its like a cylinder, with a little white plastic peice at the end
Old 06-24-2007, 10:19 AM   #15
Journeyman Plumber
Those are the ones to use, how about the rubber seats, where they long or short ones, some are long some are short. Not sure what you got in the rebuilt kit you bought.
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Symons shower faucet ptedone Plumbing 2 01-01-2007 10:03 PM
