Valley II Roman Tub Faucet Circa 1983 Replacement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2011, 09:21 PM   #1
Unhappy
Valley II Roman tub faucet circa 1983 replacement
I currently have a Valley II Roman Tub Faucet (spout) that was installed in 1983 when my house was built. It is a stand alone 8" spout that looks like a faucet. The handles are placed about 8 inches on either side of the spout. It is a dark brushed brass. I want to switch it to a bath that has the same spout, as the aerator on that spout crumbled.
The tub has tile all around and a wall separating the Stall [COLOR=blue !important][COLOR=blue !important]shower[/COLOR][/COLOR] so there is no access to underneath the tub to get to the faucet. It is an acrylic marble tub.
How do I remove the aerator to get to the inside of the faucet/spout to remove it? The aerator has a 1/2" recessed screen and it really looks like I can't take it off. I can't see anywhere where a flat nose screw driver could be used to pry it off. Do I use a regular wrench or pliers to screw it off?
After I do get the aerator off, should I be able to insert an Allen wrench into the spout to release it and just pull the spout off?
Thanks,
Weeping in Texas
DEVO2 is offline   Reply With Quote
Tags
garden tub spout , roman faucet , roman spout , roman tub , valley ii
Outside water faucet replacement. As simple as it looks? ajtool Plumbing 3 07-27-2010 05:51 PM
Roman tub faucet, no access, can it be done? HOW? Fix'r Up'r Plumbing 8 06-14-2009 05:12 PM
Roman Tub Faucet Removal LennyM Plumbing 3 08-02-2008 02:22 PM
Replacing Faucet for a Roman tub phibui Plumbing 8 02-14-2008 07:28 PM
Faucet replacement rondo Plumbing 2 12-03-2006 01:49 PM
