Old 11-18-2007, 05:46 PM   #1
Vaillant turbo max vue 282/ie
hi can anyone help i have a vaillant turbo max vue 282/ie when the heating is switched off or timed to go off after 5 minutes the yellow ignition indicator light flashs the boiler then wont work heating or water you have to switch the boiler on and off at the switch and then the yellow light stops flashing and the boiler works can any one help
peterdonovan is offline   Reply With Quote
Old 12-08-2007, 10:56 AM   #2
Hi Peter,
I have the same problem with my boiler it's a turbo max vue 242 e.
Did you ever resolve the problem.
Peter Saunders is offline   Reply With Quote
