Old 08-28-2009, 07:41 PM   #1
Vacuum relief valve?
I'm looking for a valve for an unusual circumstance. I have a large water tank that has a vent line running from the top. When the tank is overflowing, it uses the vent line to dispose of excess water. When the tank is drained from the bottom, it uses the vent line as an air vent.
If the vent line is blocked when the tank is draining, it will cause a vacuum that can damage the tank. I would like to install a valve on the vent line to allow emergency vacuum relief, but low pressure water still needs to flow freely in both directions past the vacuum relief valve without any leakage. I'm unable to add a valve directly to the tank and it needs to be installed on the vent line.
Is there a valve that will work and what kind is it. My vent line is 3/4, but I have size flexibility because of the tee. Will this fit my needs or will it leak?
http://www.plumbersurplus.com/Prod/Watts-Vacuum-Relief-Valve-N36-M1-3-4-(0138458)/5920/Cat/224?utm_medium=referral&utm_source=googlebase&cvsf a=63&cvsfe=2&cvsfp=5920
Hope my description is not too confusing. Thanks!
walker44 is offline   Reply With Quote
Old 08-29-2009, 07:25 AM   #2
I think what you are describing is a T&P(temp/pressure) relief valve, although they are usually on the side of the tank. What was in your link is not the same thing. A pic of your existing valve would help us.
Old 08-29-2009, 06:40 PM   #3
Does the valve need to be automatic or would manual control work? What kind of material is the overflow made from? What diameter? How is it connected to the tank? Is there a threaded elbow? Picture would help.
bob22 is offline   Reply With Quote
Old 08-29-2009, 11:29 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
That vacuum relief valve in the link should work just fine. You'll just need a 3/4" female adapter to screw it in to. We are required to use them on bottom fed water heaters.
JDC is offline   Reply With Quote
Old 08-30-2009, 04:05 PM   #5
Thanks for the help!
Just bill: There is no existing valve because this is a DYI add on. The tank is a cold water storage tank, so temp and inside pressure is not an issue.
Bob22: The valve needs to be automatic, the overflow line is made out of 3/4 heavy duty plastic flex tubing. I was planning on inserting the valve in line with a barbed / threaded female tee.
JDC: Thanks, I was also thinking about using a standard check valve, but I think the Vacuum relief valve would work better. Do you know if the vacuum valve needs to remain vertical to work?
Old 08-30-2009, 04:08 PM   #6
GC/Master Plumber/Mech
Are you just concerned with debrie getting into the tank?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-30-2009, 04:11 PM   #7
I’m not concerned about debris. It’s not drinking water and the vent has a screen to stop larger debrie from entering the tank. I will try to post pictures.
Old 08-30-2009, 05:04 PM   #8
They what are you trying to accomplish that a simple 90 deg fitting won't do.
Old 08-30-2009, 05:11 PM   #9
Plumer101: I dont think I understand your question. a "90 deg fitting" ( i think you mean tee) would defaet the pupose of a vent line and allow water to pass where i dont want it. I need something that will allow air to pass into the system, but will not allow water to exit
Old 08-30-2009, 05:31 PM   #10
http://i709.photobucket.com/albums/w...r44/Vacuum.jpg
Old 08-30-2009, 05:33 PM   #11
I get it now. When the tank fills you don't want water to be released when it is full.
HOW TO diagnose gas valve problems Nestor_Kelebay How To Guides 24 02-10-2012 08:49 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
