VA Code Says 1.5" Inch Pipe On Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2011, 08:40 AM   #1
VA code says 1.5" inch pipe on shower drain
I'm building a custom shower on a basement concrete floor that will use a sanishower system. The state of Va code states that 1.5" pipe can be used for the drain. However I cannot find any 1.5" shower drains. I really don't want to use 2" pipe because of the limited vertical space. I have built a raised floor using 2 x 6's to account for the plumbing under the shower. Using 2 pipe the raised floor is not high enough. The drain will go through the wall under the shower and into the utility room where the sanishower unit will be. My question is, can I use a reducing bushing in the shower drain to make it 1.5 inches instead of 2 inches. This will be inspected by the county so I want to make sure everything is up to code.
wcarroll is offline   Reply With Quote
Old 08-10-2011, 10:04 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I would use 2" Pipe anyway. When it gets clogged with hair and soap scum it will be easier to put a snake through the trap.
Trust me, it will fit.
Post a picture of the location you're trying to put it and the pipe you're working with.
Journeyman Plumber
Old 08-10-2011, 10:31 AM   #3
Thanks Alan..
I will post a picture this evening after I get off work.. Dry fitting the p-trap and shower drain together it looks like I need another 1 to 2 inches in height to clear the plumbing using the 2 x 6 raised floor..
Old 08-11-2011, 12:07 AM   #4
Doing it myself
Alan's Avatar
What's the material below the raised 2x6 floor? Concrete or wood?
Either way you can take some of it out for the bottom of the p-trap to sit in so that it will fit in the joist bay.
I believe the 2" p-traps we use are a vertical dimension of 7-1/2" so they should fit in a 2x8 bay, but 2x8 now are 7-1/4, so they don't anymore. At any rate, the amount of material you need to remove below it is pretty small.
Journeyman Plumber
Possible to join PVC drain pipe to old iron pipe? darsunt Plumbing 7 03-01-2014 02:53 PM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 11:07 AM
Shower drain not centered for new fiberglass shower pan keyboarder Plumbing 9 12-01-2010 09:30 PM
Solid 4 inch black flex drain pipe backflow preventer fuge6 Landscaping & Lawn Care 4 11-14-2010 11:58 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
