Closed Thread
Old 11-18-2006, 09:24 PM   #1
Default utility sink pump
Good evening! I Need to get a pump for a utility sink that will pump the water about 8 ft. high. The only thing emptying into the sink will be a washing machine, about 7-8 loads a week. would anyone have any ideas on names and prices and place to purchase pump. Thanks in advance.
furiousstyles is offline
Old 11-18-2006, 10:08 PM   #2
World famous jerk.
For a utility sink, I always like the direct mount style. They are super simple, and are easy to install. They also have less parts to fail. Here's a link to a popular one: http://www.hartell.com/corp/details/...TI3869,00.html The direct mount ones have a little switch that senses when there's water going down the drain, and the pump kicks on. The one I linked to you can buy directly from that manufacturer on their site; about 300 bucks. That's about what you'd pay for any good pump to pump out a utility sink.
mdshunk is offline
Old 11-19-2006, 09:01 AM   #3
Whatever type pump you buy and install, I would suggest using something to "filter" the washer discharge water. It contains LOTS of lint which will cause problems down the road. Simplest thing I have seen/used is a knee-high nylon stocking. They are cheap and disposable. Secure one with a clamp on the end of the discharge hose and when it gets full of lint, pitch it and replace with another one. For those reading this post that do not discharge the water into another vessel (utility sink etc), do not install these on your hose and drop it into the standpipe. Should it fall off, you will be trying to dig it out of the trap, which is not a fun project. Being in the standpipe also makes it non-visible and if it fills up, the water will backflow and flood the area.
If you have never made a mistake, you haven't done much.
majakdragon is offline
Old 11-06-2009, 05:37 PM   #4
Default utility pump
Depending on how high it needs, why not just let the washer pump it? even if you need to build a small platform (I've done) seems redundant to have the washer pump , then have a pump do it again. A washer will pump about 6' high...Dave
daver80 is offline
Old 11-06-2009, 05:52 PM   #5
Extreme DIY Homeowner
Scuba_Dave's Avatar
This thread is 3 years old....
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is offline
Closed Thread
More On This Topic
Hi. I'm Albert Hedgepeth with Expert Village. Today we are going to talk a little bit about boat maintenance. What we are going to talk about now is a macerator. A maceration system is used to chop up sewage that is on your boat and the discharge from... Read More »
How to Check Boat Hoses
How to Check Boat Hoses by Expert Village
Hi. I'm Albert Hedgepeth at Expert Village. Today we are going to talk a little bit about boat maintenance. Another necessity whenever you are actually starting out for the first time or whenever you're taking your boat out of winterization is going to... Read More »
If you spend a lot of money on your hosiery, you want to wash it properly to ensure that it remains undamaged. Due to the fragile nature of panty hose, they need to be handled delicately. Taking good care of your panty hose will allow the undergarments... Read More »
Hello, my name is Michael Raines. And we're on Expert Village. Here's your typical set-up. Here is your disposal unit. Now, this one happens to be a one-third horsepower. They come in one-half horsepower, three-quarter horsepower, and for some of the... Read More »
On a boat, they call the toilet the head. So on this boat, this is what we call a head. It has the toilet in it and it has also a dual purpose shower. Now toilets or heads on sailboats are kind of a little complex animals, so there's two parts to it. You... Read More »
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 12:27 PM
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 1 04-22-2007 02:32 PM
Cement Utility Sink - Cracks and Leaks amazinlittledevil Plumbing 3 01-25-2007 04:59 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-09-2006 12:42 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 04:30 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
